03-14-2017
09:53 PM
- last edited on
03-25-2019
08:42 PM
by
ciscomoderator
Dear All
These day I have a issue on 3way conf on cisco voice router .
pstn ---- 3rd party VG ---- (sip) ---- C2911 --- SIP Phone
I can not pass trough the key pad for pstn call.
So I am telling this for get some idea for soulve this issue.
here is the configure and Logs.
C2911
dial-peer voice 9501 voip
destination-pattern 8699
session protocol sipv2
session target ipv4:destination
voice-class h323 100
dtmf-relay rtp-nte h245-alphanumeric
codec transparent
debug log
495787: Mar 15 11:42:06.698: //10221/F19954CC8171/CCAPI/cc_api_call_digit_begin:
Consume mask is not set. Relaying Digit 0 to dstCallId 0x27EE
495788: Mar 15 11:42:06.698: //10221/F19954CC8171/CCAPI/cc_relay_digit_begin_for_3way_conference:
Check DTMF relay digit begin for 3way conf
495789: Mar 15 11:42:06.698: //10221/F19954CC8171/CCAPI/cc_api_call_digit_end:
495790: Mar 15 11:42:06.698: //10221/F19954CC8171/CCAPI/cc_relay_digit_end_for_3way_conference:
Check DTMF relay digit end for 3way conf
495791: Mar 15 11:42:07.842: //10221/F19954CC8171/CCAPI/cc_api_call_digit_begin:
Consume mask is not set. Relaying Digit 5 to dstCallId 0x27EE
495792: Mar 15 11:42:07.842: //10221/F19954CC8171/CCAPI/cc_relay_digit_begin_for_3way_conference:
495793: Mar 15 11:42:07.842: //10221/F19954CC8171/CCAPI/cc_api_call_digit_end:
495794: Mar 15 11:42:07.842: //10221/F19954CC8171/CCAPI/cc_relay_digit_end_for_3way_conference:
495795: Mar 15 11:42:08.130: //10221/F19954CC8171/CCAPI/cc_api_call_digit_begin:
Consume mask is not set. Relaying Digit 3 to dstCallId 0x27EE
495796: Mar 15 11:42:08.130: //10221/F19954CC8171/CCAPI/cc_relay_digit_begin_for_3way_conference:
Thans a lot.
03-15-2017 04:44 AM
Hi, the "h245-alphanumeric" is an H.323 protocol and you cannot use this with SIP.
It's not supported. Leave only "dtmf-relay rtp-nte" in your config.
With this option your gateway will negotiate RDC2833 DTMF relay method.
What method is supported by your 3PTY gateway?
You can also test SIP INFO using "dtmf-relay sip-notify" options.
If you use not compressed codec (g.711 only) you can remove the option "dtmf-relay" and test dtmf in band method. In this case the DTMF tones are sent as voice directly to your PSTN line.
Regards.
03-15-2017 11:58 PM
Hi, Thanks your reply.
I already test all option.
But I didn't success this issue.
I can hear tone from remote pstn but I can not send extra button for remote local call.
This is a exact problem.
Thanks a lot.
03-19-2017 04:20 AM
Can you kindly add the output of "debuc ccsip message" from the 2911?
I want check the DTMF method negotiated from the third party gateway, your router and the SIP phone.
Thanks.
03-19-2017 08:39 AM
RTP-NTE isn't supported in CFB (hardware or software).
Change this to another SIP method such as SIP-NOTIFY or SIP-KPML.
The h323 command won't take effect because you have SIP dialpeer
