IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6709 Views
  • 14 replies
Hello, I have to perform a Refresh Upgrade to 10.5 for a client who has the following UC apps on a virtual environment:CUCM version 9.1.1IM and Presence version 9.1.1CUC (Unity Connection)  version 9.1.1 A. I see on the CUC Upgrade document below:htt...
Hi I have a SIP trunk connected to H323 gateway , that registered to cucm 11. the SIP is 100 lines , each two lines will serve one company  and there are two operators for all companies, I need to help the operators to differentiate between the comi...
Hi, Please i need some help on one-way issue experiencing whenever i try to migrate a third-party switchboard device to route calls through our new SIP gateway. New SIP provider will accept only G729 but preferred MTP on third-party SIP trunk to CUC...
Hi Experts, We have an issue here with unity 10.5. The scenario is when some one call the queue ( UCCX 10.5 )and after the queue wait time exceeds the configured limit for example 2 minutes , then they will get an option to leave a message. It works ...
S N by Level 1
  • 543 Views
  • 5 replies
Hello Community, I have tried to upload some costum images to CUCM, while updating the List.xml in order to change the Wallpaper, mainly on Cisco 8845, however I receive the error on the display "Unable to obtain additional wallpapers from server". ...
Dear, I have a one way sip trunk for incoming call from sip provider. and CUCM 10.5 and Contact Center 10.5 and 2911 router. my scenario is like this: CUCM(172.16.X.X)--------------(H323)---------(172.16.X.X)Router(10.X.X.X)---------(SIP)-----------...
Hi, I have configured SRTS as under: call-manager-fallback max-conferences 8 gain -6 transfer-system full-consult ip source-address 192.168.132.1 port 2000 max-ephones 5 max-dn 5 keepalive 20 CUCM configurations are attached. issue is that from...
