CIPP 7841 does not register with CME 10.5
michal.psota
I have serious problem with registration of IP phone 7841 in CME 10.5 in my lab environment.
I am totally frustrated with it for several days and cannot find any solution or advice
on Cisco forums as well as on Internet. I tried almost everything what I found:
reset config on the phone - did not help
load another firmware to phone via separate TFTP - did not work at all
upgrade CME from 10.0 to 10.5 - did not help
The phone still says "Unprovisioned" on the display. I am absolutely lost.
Here are parameters of my lab:
Router - physical c2911 box, IOS 15.0(1r)M16, Image: c2900-universalk9-mz.SPA.154-3.M6a.bin, CME version 10.5
Phone - IP Phone 7841 with sip78xx.11.0.1SR1-2 (preinstalled from factory)
Here is relevant config from the router:
version 15.4
hostname CME1
ip dhcp excluded-address 10.0.0.1 10.0.0.100
ip dhcp pool voip-pool
network 10.0.0.0 255.255.255.0
option 150 ip 10.0.0.5
default-router 10.0.0.5
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 1200 min 300
voice register global
mode cme
source-address 10.0.0.5 port 5060
max-dn 20
max-pool 10
load 7841 sip78xx.10-4-1SR2-85-3PCC.loads
authenticate register
authenticate realm all
logo load
file text
create profile sync 0111849074631201
voice register dn 1
number 1000
allow watch
voice register dn 2
number 1002
voice register dn 4
number 1004
voice register pool 1
busy-trigger-per-button 1
id mac 0076.861B.DA37
username Misak password 1234
codec g711ulaw
no vad
hw-module pvdm 0/0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 10.0.0.5 255.255.255.0
duplex auto
speed auto
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip tftp source-interface GigabitEthernet0/0
tftp-server flash:/kern2.78xx.10-4-1SR2-85-3PCC.sbn alias kern2.78xx.10-4-1SR2-85-3PCC.sbn
tftp-server flash:/rootfs2.78xx.10-4-1SR2-85-3PCC.sbn alias rootfs2.78xx.10-4-1SR2-85-3PCC.sbn
tftp-server flash:/sboot2.78xx.10-4-1SR2-85-3PCC.sbn alias sboot2.78xx.10-4-1SR2-85-3PCC.sbn
tftp-server flash:/sip78xx.10-4-1SR2-85-3PCC.loads alias sip78xx.10-4-1SR2-85-3PCC.loads
tftp-server flash:/SEP0076861BDA37.cnf.xml alias SEP0076861BDA37.cnf.xml
access-list 23 permit 10.10.10.0 0.0.0.127
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
gatekeeper
shutdown
telephony-service
max-ephones 10
max-dn 10
ip source-address 10.0.0.5 port 2000
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Mar 02 2017 11:02:05
end
I enabled following debug commands:
debug tftp events
debug ccsip messages
and the result is attached.
Is there anyone in Voip world who can help me, otherwise I will give it up and start with carott growing .
Many thanks to all in advance !
Michal
Hi Michal,
As mentioned by critchey880, you missed to bind the dn to the voice register pool. Also phone type is missing.
So try the following:
number 1 dn 1
type 7841
Then go to
no create profile
create profile.
Reset the phone
You can check whether the phone config is built using the command "show voice register tftp-bind"
Rajan
Pls rate all useful posts
critchey880
I am no expert but I do see a few things that stick out:
No DN associated with the pool you created
You say your using 11.0 firmware pre-installed but your telling the phone to load 10.4.  Which is it actually running?
Hi Michal,
number 1 dn 1
type 7841
Then go to
no create profile
create profile.
Reset the phone
Rajan
Hi Rajan,
many many thanks, I am surprised how can I forgot on such thing as number binding.
Now it is working perfectly. I am sorry for stupid post, you helped me a lot !
Best regards,
Michal
Glad it worked. Cheers.
- Rajan
