CME 8.5 and callcentric.com debug
alexten1983
Hello need some help with debug.
callcentric.com says to check the voice mail box all needed is to dial from the local number is *83 and or *123. I have set up this dial peer but get fast busy when I try to use it.
dial-peer voice 123 voip
 corlist outgoing Door-National
 description *** Calls VoiceMail ***
 destination-pattern *123$
 session protocol sipv2
 session target dns:callcentric.com
 dtmf-relay sip-notify rtp-nte
 codec g729br8
Hope below link is of great help to you.
https://supportforums.cisco.com/discussion/11993691/sip-incoming-authentication
Also double check your account information and password as per the error code 403 Incorrect Authentication.
Abhay
Kindly rate all helpful posts !!!
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
alexten1983
Correct me if I'm wrong but I think the problem might be in this
From: "Kitchen" <sip:1011@callcentric.com>;tag=92866EC-6FD
I think it should be from the number that is registered to the account and not from the extension.
Abhay
Abhay Singh Reyal
alexten1983
Thank You. That did fix the problem.
