Cisco 1861E basic configuration (CME)
jahahne
Hey guys,
right know, I want to get some basic knowledge about CME for my CCNA Collaboration. Therefore, I've got an 1861 Integrated Service Router.
I currently have some struggle to connect to my 8961 IP Phone and my pc. Maybe I did some basic knowledge error in my configuration, but I can't find it.
My goal is, to have a vlan10 for data traffic und vlan20 for voice traffic. My pc should receive the ip via DHCP from the 1861, the phone also. Therefore, I've created 2 dhcp ip ools.
But nothing does work currently. I do not get
Would someone of you be so kind, to have look over my current configuration? Does it make sense? I hope so, its quite hard to do the Collaboration stuff without so much R&S experience.
Current configuration : 2811 bytes
! Last configuration change at 12:31:13 UTC Sat May 19 2018
version 15.2
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
network-clock-participate wic 1
ip dhcp excluded-address 192.168.10.1 192.168.10.5
ip dhcp excluded-address 192.168.20.1 192.168.20.5
ip dhcp pool DATA10
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
ip dhcp pool VOICE20
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
option 150 ip 192.168.20.1
no ip domain lookup
ip cef
no ipv6 cef
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
voice-card 0
license udi pid C1861-SRST-B/K9 sn FCZ12326011
interface FastEthernet0/0
ip address 192.168.5.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
interface FastEthernet0/1/0
switchport access vlan 10
switchport voice vlan 20
no ip address
interface FastEthernet0/1/1
no ip address
interface FastEthernet0/1/2
no ip address
interface FastEthernet0/1/3
no ip address
interface FastEthernet0/1/4
no ip address
interface FastEthernet0/1/5
no ip address
interface FastEthernet0/1/6
no ip address
interface FastEthernet0/1/7
no ip address
interface FastEthernet0/1/8
no ip address
interface BRI0/1/0
no ip address
interface BRI0/1/1
no ip address
interface Vlan1
no ip address
interface Vlan10
no ip address
interface Vlan20
mtu 256
no ip address
ip forward-protocol nd
no ip http server
ip route 0.0.0.0 0.0.0.0 192.168.1.1
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control
description Music On Hold Port
mgcp profile default
telephony-service
max-ephones 10
max-dn 20 no-reg both
ip source-address 192.168.20.1 port 2000
max-conferences 4 gain -6
transfer-system full-consult
ephone-dn  1
number 1001 no-reg both
label 1001
description ciscophone_1001
ephone  1
description cisco8861
mac-address 3037.A617.9BD6
button  1:1
line con 0
exec-timeout 0 0
logging synchronous
no modem enable
speed 115200
line aux 0
line vty 0 4
login
transport input all
end
Any suggestions?
Best Regards
Jan
Dennis Mink
when you give your pc a static ip address in the data vlan can you actually ping the router?
(configure a port just only in vlan 10 data and connect the pc to that, then try dhcp on the same port)
Please remember to rate useful posts, by clicking on the stars below.
R0g22
You don't really need so much R&S but you should know VLANs,SVI, basic ip routing/subnetting stuff. That is pure CCNA.
Now coming to the issue at hand, does your phone get it's VLAN and then an IP address ?
You can do a "debug ip dhcp server packets/events" on the router in order to check the ip assignment. You can also do a "show ip dhcp bind" to see what all IP addresses have been leased out.
