Cisco 2620
Hi All,
I want to check whether Cisco 2620 is support for voice gateway and call manager ? I know that 2611XM is supported.
paolo bevilacqua
It would, but it's such and old, slow and limited model, that you don't want to loose any time with it.
Hi Paolo,
Is there any matrix table for router requirement voice gateway, cause I couldn't find it. Have you try 2620 as a voice gateway before ?
All the information that you need can be found on cisco.com, or consult a Cisco Reseller.
As mentioned before, a 2620 today is essentially useless.
