Cisco 2621XM Router compatibility with CCP - Home Lab
nate45scott
Hi all,
I've got a Cisco 2621XM Router (purchased per the suggestion of CBTNuggets) that I'm trying to use in my home lab. I'm to the point where CCP can discover my router, but I get this far to find that my router isn't supported any further. I'm assuming that it not being supported is why I cannot select CUCME as my option for IP Telephony (it is currently grey instead of being clickable).
Is there anything that I can do to make my Router compatible with CUCME? I can provide whatever information necessary.
markbatts
Most likely the  version of IOS you are running.Post a show version
Cisco IOS Software, C2600 Software (C2600-IPVOICEK9-M), Version 12.4(9)T2, RELEASE SOFTWARE (fc4)
 That's the version I'm running.
