Cisco 2801 and Skype
gagomez85
Hi, I am trying to config a Sip trunk on my router this is a Cisco Router 2801 with ios c2801-ipvoicek9-mz.124-25b.bin.
My actual configuration is the following:
dial-peer voice 9997 voip
description Skype Incoming
voice-class codec 1
session protocol sipv2
session target sip-server
incoming called-number  <Skype User 999XXXXXXX>
dtmf-relay rtp-nte
no vad
dial-peer voice 9998 voip
description Skype Outgoing
destination-pattern 8003333333
voice-class codec 1
dtmf-relay rtp-nte
no vad
sip-ua
authentication username <Skype User 999XXXXXXX> password <Skype User Password> realm sip.skype.com
registrar dns:sip.skype.com expires 3600
sip-server dns:sip.skype.com
can someone help me.
Gerardo
7 Replies 7
Ayodeji Okanlawon
Gerardo,
What do you need help with?
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
My configuration is not working at this time, so I need help to troubleshoot this configuration.
Send us a "debug ccsip messsages"
Aokanlawon:
This is the debug of the call:
14w5d: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x640B5D74,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_PORT; Incoming Dial-peer=3
14w5d: //-1/87838802B5B2/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=4, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=4
   Result=Partial Matches(1) after DP_MATCH_DEST
14w5d: //-1/87838802B5B2/DPM/dpMatchPeersMoreArg:
   Result=MORE_DIGITS_NEEDED(1)
   Calling Number=, Called Number=44, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=44
   Calling Number=, Called Number=44#, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=44#
   Calling Number=, Called Number=44#0, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=44#0
   Calling Number=, Called Number=44#08, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=44#08
   Result=Success(0) after DP_MATCH_DEST
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=9998
   Result=SUCCESS(0)
     2: Dial-peer Tag=8
14w5d: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
14w5d: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
14w5d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:8003333333@sip.skype.com:5060 SIP/2.0
Via: SIP/2.0/UDP  200.47.3.252:5060;branch=z9hG4bK2A6DB1A7E
To: <>8003333333@sip.skype.com>
Date: Mon, 25 Mar 2013 21:19:37 GMT
Call-ID: 882F09BB-94C811E2-B5B5A8FD-DFB532DD@200.47.3.252
Supported: 100rel,timer,replaces
Min-SE:  1800
Cisco-Guid: 2273544194-2496139746-3048384765-3753194205
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, COMET, REFER, SUBSCRIBE, NOTIFY, INFO, UPDATE, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1364246377
Contact: <200.47.3.252:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Length: 306
v=0
o=CiscoSystemsSIP-GW-UserAgent 9627 6283 IN IP4 200.47.3.252
s=SIP Call
c=IN IP4 200.47.3.252
t=0 0
m=audio 18872 RTP/AVP 0 8 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Contact: <>8003333333@sip.skype.com:5060;maddr=63.209.144.201;transport=udp>
Content-Length: 0
Received:
SIP/2.0 404 Not Found
To: <>8003333333@sip.skype.com>;tag=c990d13f-13c4-5150b63c-95b737aa-23b82bdd
CSeq: 101 INVITE
Content-Length: 0
14w5d: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
14w5d: //34190/87838802B5B2/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x63476C5C
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           :
Called Number            : 8003333333
Source IP Address (Sig  ): 200.47.3.252
Destn SIP Req Addr:Port  : 63.209.144.201:5060
Destn SIP Resp Addr:Port : 63.209.144.201:5060
Destination Name         : sip.skype.com
14w5d: //34190/87838802B5B2/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0
Source IP Address (Media): 200.47.3.252
Source IP Port    (Media): 18872
Destn  IP Address (Media): 0.0.0.0
Destn  IP Port    (Media): 0
Orig Destn IP Address:Port (Media): 0.0.0.0:0
Disconnect Cause (CC)    : 1
Disconnect Cause (SIP)   : 404
Sent:
ACK sip:8003333333@sip.skype.com:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Gerardo,
The sykpe server is saying that it cant find the number you dialled
Received:
You need to ensure you are dialling the correct number or speak to your provider to know why they are unable to route the call
Anas Abueideh
Level 9
Level 9
you need to configure DNS to resolve sip.skype.com
Anas
please rate if it is helpful
I can ping sip.skype.com since my router.
