Showing results forĀ
Search instead forĀ
Did you mean:Ā
CISCO 2821 and VoIP
KS3
Hi!
I likely will bought router CISCO 2821.
Seller is writing about this router:
- version is Cisco IOS Software, 2800 Software (C2800NM-IPVOICEK9-M), Version 15.1(3)T, RELEASE SOFTWARE (fc1)
- and has PVDM2-32 channel VOICE and PVDM2-64 channel VOICE
- and some  numberstring C2800NM-IPVOICEK9-M.
My question is, Is it router support VoIP and is it this version software has Call Manager Express.
I have read this router has licence for 48 telephons.
Kind Regards.
Yes, the C28XXNM-IPVOICEK9-M set of IOS versions supports VoIP.
Yes, this version will run CME.
Rajan
Yes, this gateway supports VoIP and you can register up to 50 phones when configured as Call Manager Express.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme86spc-htm.html
But if you are going to deploy it in production and needs support for this, you need to look for any other model as this is end of life long back.
https://www.cisco.com/c/en/us/products/collateral/routers/1800-series-integrated-services-routers-isr/qa_c67-631674.html
Rajan
Pls rate all helpful posts by clicking the star below
