01-16-2012 07:56 AM - edited 03-16-2019 09:01 AM
Im trying to configure a sip trunk with my isp on a 2900 series. Need help
Solved! Go to Solution.
01-17-2012 01:02 PM
now its 404
The Call Setup Information is:
Call Control Block (CCB) : 0x2CD73768
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number :
Called Number : 35552901060
Source IP Address (Sig ): 192.168.207.77
Destn SIP Req Addr:Port : 80.78.66.70:5060
Destn SIP Resp Addr:Port : 80.78.66.70:5060
Destination Name : 80.78.66.70
Jan 17 21:07:11.955: //13323/B2DC8DC79CDF/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : g729br8
Negotiated Codec Bytes : 20
Nego. Codec payload : 18 (tx), 18 (rx)
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0 (tx), 0 (rx)
Source IP Address (Media): 192.168.207.77
Source IP Port (Media): 24754
Destn IP Address (Media): 80.78.64.16
Destn IP Port (Media): 23024
Orig Destn IP Address:Port (Media): [ - ]:0
Jan 17 21:07:11.955: //13323/B2DC8DC79CDF/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC) : 1
Disconnect Cause (SIP) : 404
01-17-2012 01:13 PM
404 indicates unallocated number, so the 150 extnesion does not appear to be found. I see you have cor lists defined, but since you did not post the full config, can it be that COR list is blocking the call?
Not, that it matters here, but why are you using g729br8 codec, and not g729r8?
01-17-2012 01:16 PM
if i change codec ?
01-17-2012 02:28 PM
No the corlist is not blocking anything on any dial peer
