Cisco 2901 Router - Call Manager/Unity Express
phil.garrelhas
We are looking at replacing our current partial PRI with a SIP trunk (through Rogers)
Just wanted to ensure that our current VoIP infrastructure is compatible.
1. Call Manager/Unity runs off a Cisco 2901.
      - Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(2)T1, RELEASE SOFTWARE (fc1)
2. IP Phones are a mix of 7960, 7940 and a 7920.
3. Cisco IP Communicator  (soft phone).
Also, not sure if this is the appropriate place to ask, but what are the costs for:
- a session border monitor applicance
- SIP licensing (I believe this is a one time license fee)
Thanks.
There's your CUCME license - "uck9"
I have the same router / license as you and I have two SIP trunks and a PSTN FXO. I dont believe there is any additional licensing involved. I do not use a CUBE - I terminate the SIP trunk directly on the CUCME router. I have secured this through my firewall and are inspecting SIP in and out. My suggestion is try / lab it up to gain an understanding of how it may work for you. You may find you need a CUBE for other reasons.
8 Replies 8
Jaime Valencia
Assuming you're talking about CME and not CUCM, yes, the ISR is compatible
Cisco Unified CME and Cisco IOS Software Version  Compatibility Matrix
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
CUE runs on a separate module
Cisco Unity Express Compatibility Matrix
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/unity_exp/compatibility/cuecomp.htm
Those phone models will work fine with CME, as well as IPC.
There's no sip license on CME. If you need to configure SIP phones or SIP trunk you can do so with the CME features.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Here is the "About" info from our CM and Unity Express.
About the System
Cisco Unified Communications Manager Express
OS Description Cisco Internetwork Operating System
Cisco IOS (tm) C2900
Cisco IOS Software C2900-UNIVERSALK9-M
Software Version 15.1(2)T1 / CME 8.1
Feature Package IP|SLA|IPv6|IS-IS|FIREWALL|PLUS|QoS|HA|NAT|MPLS|VPN|LEGACY  PROTOCOLS|3DES|SSH|APPN|IPSE
GUI Version 8.0.0.0 (Compatible with IOS  15.0(1)XA)
Cisco Unity Express - Administration
Version 8.0.2
paolo bevilacqua
All seem oood to go. You will need UC license for the 2901.
What is the UC license? Our SIP trunk vendor mentions that a SIP license would be required. Are they both one in the same?
SteveOrfanos
Level 5
Level 5
You would require CUBE licenses for each SIP trunk.
How comes? I don' t think he will since the OP simply wants to replace an ISDN with a SIP provider on his CUCME router.
OP can you post the output of the "show license" command? You say you are already running the 2901 as a CUCME, but the "about the system" doesn't mention your "uck9" license, consequently I think Paulo suggested you would then need that. If it is a voice bundle then you will have the uck9 license already (or UC license).
As Java said, there is no additional licenses required.
Hi Tony,
Here is the output of the sh license command.
Index 1 Feature: ipbasek9
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
Index 2 Feature: securityk9
        Period left: 8  weeks 4  days
        License Type: Evaluation
        License State: Active, Not in Use, EULA not accepted
        License Priority: None
Index 3 Feature: uck9
Index 4 Feature: datak9
Index 5 Feature: gatekeeper
Index 6 Feature: SSL_VPN
        License Count: 75/0/0  (Active/In-use/Violation)
Index 7 Feature: ios-ips-update
Index 8 Feature: SNASw
Index 9 Feature: hseck9
Index 10 Feature: WAAS_Express
