07-24-2012 08:05 AM - edited 03-16-2019 12:21 PM
Dear All,
We have Cisco 2911 router that come with configuration like this:
Cisco 2911 come with IOS version 15.0(1r)M15
Cisco Unity Express 8.6.1 in slot/sub-slot 0/0
After we turn on Cisco 2911, we found that VIC2-4FXO card have Orange LED when installed on NM-HDV2.
On Show version it says "20 Voice FXO interfaces", but when we show voice port summary it only show voice port from 0/0/0 until 0/3/3.
We have try show diag, the result NM-HDV2 and VIC2-4FXO card that installed on NM-HDV2 has detect.
We have try installed another VIC2-4FXO on NM-HDV2 and the result is same (VIC2-4FXO have orange LED when installed on NM-HDV2)
Our question:
- What cause VIC2-4FXO have Orange LED when installed on NM-HDV2 and cannot detect by show voice port?
- Are PVDM3-16 have correlation with amount VIC2-4FXO card that use?
- What command that can use to check license FL-CUE-PORT-2 already installed on Cisco 2911?
We hope you can give us information about it
Thanks For Your Attention
We attach Cisco2911 with VIC2-4FXO have orange LED when installed on NM-HDV2. Show version, show diag and show voice port summary
07-24-2012 08:42 AM
can you check if your NM-HDV2 has any PVDM resource on board.
I think your order should have included a
PVDM2-8
For the NM module
Alex.
Please rate useful posts.
07-25-2012 08:37 AM
Dear All,
Thanks for information that you give to us. We have checked that Cisco 2911 only have 1 PVDM3-16 installed and NM-HDV2 does'nt have PVDM resource on board.
We have report it to our manager.
