Cisco 2921 - Outbound Fax from Castelle Fax Server via VIC2-2BRI-NT/TE
btmulgrew
Level 4
Level 4
Hi -  We have a Cisco 2921 with c2900-universalk9-mz.SPA.150-1.M3.bin with uc and ipbase licensd features.
The 2921 has a VWIC2-1MFT-T1/E1 (running as E1) for voice termination and also has 2 x VIC2-2BRI-NT/TE for connectivity to the fax server.
All L3 isdn is up (multiple frames established) and no errors on controllers or interfaces.
Inbound faxing is fine, however, outbound faxes are of poor quality.
I have noticed that outbound faxes report dsp resource errors as below, however, we have plenty of dsps as below:
1 x PVDM3-32
1 x PVDM3-64
with no sccp dsp resources defined for xcoders, cfbs etc I would expect these all to be available for voice termination?
q931 debug extract is below
17:14:25.333: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8C0B
*Feb  8 17:14:25.337: ISDN BR0/1/0 Q931: TX -> ALERTING pd = 8  callref = 0x86
Progress Ind i = 0x8188 - In-band info or appropriate now available
*Feb  8 17:14:30.433: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x8C0B
*Feb  8 17:14:30.437: %ISDN-6-CONNECT: Interface Serial0/0/0:29 is now connected to 01202652071 N/A
*Feb  8 17:14:30.437: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0C0B
*Feb  8 17:14:30.437: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to N/A N/A
*Feb  8 17:14:30.437: ISDN BR0/1/0 Q931: TX -> CONNECT pd = 8  callref = 0x86
Channel ID i = 0x89
  Exclusive, B1
*Feb  8 17:14:30.461: ISDN BR0/1/0 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x06
*Feb  8 17:14:35.701: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
*Feb  8 17:14:35.701: %ISDN-6-DISCONNECT: Interface BRI0/1/0:1  disconnected from unknown , call lasted 5 seconds
*Feb  8 17:14:35.701: %ISDN-6-DISCONNECT: Interface Serial0/0/0:29  disconnected from 01202652071 , call lasted 5 seconds
*Feb  8 17:14:35.701: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8  callref = 0x86
Cause i = 0x82AC - Requested circuit/channel not available
*Feb  8 17:14:35.701: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x0C0B
Cause i = 0x80AC - Requested circuit/channel not available
*Feb  8 17:14:35.733: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8  callref = 0x06
*Feb  8 17:14:35.733: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x86
*Feb  8 17:14:35.785: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x8C0B
*Feb  8 17:14:35.785: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0C0B
*Feb  8 17:15:34.977: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x16 is 0x0 0x0, Calling num 33359
*Feb  8 17:15:34.977: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x0C0C callID = 0xB3AD switch = primary-qsig interface = User
*Feb  8 17:15:34.977: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0C0C
Thanks in advance
Brian
Mark Pareja
Check this video out, it may shed some light on things for you. If your still having issues after attach your configuration and we'll break it dow to see where we might be slowing up.
T.38 Fax over IP Design Best Practices - Live Webcast
https://supportforums.cisco.com/videos/1556
