Cisco 3745 as Analogue PABX
tsolution
Hi friends my task is to setup 3745 router as analogue PABX and i need your help.
The router has 2 NM-2V with 8 Voice Ports where 6 are FXS and 2 are FXO
1 FXO is connected to BT Landline , 1 FXO is free for future uses.
6 FXS are connected to standard analouge phones
this router is already connected through VPN tunnel to another location which also has 6 FXS line and all FXS extentions on both locations can communicate each other perfectly.
The only new thing is we added a FXO card on this location and want that
1.user can dial all external numbers as well including international numbers.
2. when some one call on external line, all extenstion ring same time. (i was told that hunt group can only be done in CME)
3. Call transfer between extensions.
4. improve voice quality / avoid call disconnections
5. implement some basic QoS so that internet trafic works fine
6. basic logging i.e. call history etc.
7. basic security / firewall on the router.
please see sh ver and sh run as follow.
My other question is can i install CME 4.1 on this router? it it competible and if yes and i install CME 4.1 on this router, does it require any licensees as we are not using any ip phones at all?
UK2#sh ver
Cisco IOS Software, 3700 Software (C3745-IPVOICE_IVS-M), Version 12.4(23), RELE
SE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Sun 09-Nov-08 01:48 by prod_rel_team
ROM: System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
UK2 uptime is 3 weeks, 4 days, 22 hours, 57 minutes
System returned to ROM by reload
System image file is "flash:c3745-ipvoice_ivs-mz.124-23.bin"
Cisco 3745 (R7000) processor (revision 2.0) with 243712K/18432K bytes of memory
Processor board ID JHY0902K2BN
R7000 CPU at 350MHz, Implementation 39, Rev 3.3, 256KB L2, 2048KB L3 Cache
2 FastEthernet interfaces
2 Voice FXO interfaces
6 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity disabled.
151K bytes of NVRAM.
31360K bytes of ATA System CompactFlash (Read/Write)
253952K bytes of ATA Slot0 CompactFlash (Read/Write)
UK2#sh run
Current configuration : 6465 bytes
version 12.4
hostname UK2
boot-start-marker
boot-end-marker
enable secret level 2 5 $1$Fs/Z$T5ZhEpSEEGYOV5564C.0pj1
enable secret 5 $1$7S/G$lBwlBlNgxbcMuHvffFpRd8/
no aaa new-model
ip cef
ip name-server 217.37.xxx.xxx
vpdn enable
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g729br8
codec preference 4 g723r53
codec preference 5 g723r63
voice class dualtone-detect-params 100
freq-max-deviation 50
freq-min-power 35
voice class custom-cptone TEST
dualtone busy
dualtone ringback
  frequency 500 632
dualtone reorder
  frequency 500 631
  cadence 500 500
dualtone disconnect
  frequency 630
  cadence 500 500
interface Tunnel40
description UK1-UK2
ip address 16.16.16.2 255.255.255.252
tunnel source FastEthernet0/0
tunnel destination 218.205.xxx.xxx
interface FastEthernet0/0
description WAN-LINK
ip address 217.37.xxx.xxx 255.255.255.248
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
description LAN
ip address 192.168.20.254 255.255.255.0
ip nat inside
duplex auto
speed auto
router ospf 1
log-adjacency-changes
network 16.16.16.0 0.0.0.255 area 0
network 192.168.20.0 0.0.0.255 area 0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 217.37.xxx.xxx
ip dns server
ip http server
ip nat inside source list 10 interface FastEthernet0/0 overload
ip nat inside source static 192.168.20.250 217.37.xxx.xxx
access-list 10 permit 192.168.20.0 0.0.0.255
control-plane
voice-port 1/0/0
supervisory disconnect dualtone mid-call
no battery-reversal
disc_pi_off
echo-cancel coverage 24
no comfort-noise
cptone GB
timeouts initial 5
timeouts interdigit 5
timeouts call-disconnect 5
timeouts ringing 10
timeouts wait-release 1
timing hookflash-out 50
timing sup-disconnect 100
connection plar 806
voice-port 1/0/1
voice-port 1/1/0
disc_pi_off
cptone GB
timeouts call-disconnect 1
voice-port 1/1/1
disc_pi_off
cptone GB
voice-port 2/0/0
disc_pi_off
cptone GB
voice-port 2/0/1
disc_pi_off
cptone GB
voice-port 2/1/0
disc_pi_off
cptone GB
voice-port 2/1/1
disc_pi_off
cptone GB
dial-peer voice 11 pots
tone ringback alert-no-PI
destination-pattern 0T
progress_ind setup enable 3
progress_ind progress enable 8
progress_ind disconnect enable 8
no digit-strip
port 1/0/0
forward-digits all
dial-peer voice 500 voip
destination-pattern 5..
voice-class codec 1
session target ipv4:16.16.16.1
dial-peer voice 801 pots
answer-address 801
destination-pattern 801
no digit-strip
port 1/1/0
dial-peer voice 802 pots
answer-address 802
destination-pattern 802
no digit-strip
port 1/1/1
dial-peer voice 803 pots
answer-address 803
destination-pattern 803
no digit-strip
port 2/0/0
dial-peer voice 804 pots
answer-address 804
destination-pattern 804
no digit-strip
port 2/0/1
dial-peer voice 805 pots
answer-address 805
destination-pattern 805
no digit-strip
port 2/1/0
dial-peer voice 806 pots
answer-address 806
destination-pattern 806
no digit-strip
port 2/1/1
gatekeeper
shutdown
privilege voiceport level 2 shutdown
privilege configure level 2 voice-port
privilege exec level 2 traceroute
privilege exec level 2 ping
privilege exec level 2 configure terminal
privilege exec level 2 show call active voice brief
line con 0
transport output all
line aux 0
line vty 0 4
password xxxxxxxxxxxxxxxx
login
transport input all
end
UK2#
paolo bevilacqua
The answer is yes to in general . However for full features, you will need to upgrade to a new router, because the 3745 is too old to support the all the good CME features especially for FXS phones.
Note: if you have never done CME config before, recommend you hire someone that did, otherwise you will spend a lot of time and not get good results.
