CISCO 6821 MPP phone sign in password
Don Jaya
We have cisco 6821 MPP phone registered to CUCM 14 as a third-party SIP phone. Basic call features are working fine and no issue with the calls. But whenever we want to access recent call log, contact, speed dial, it prompts for password to sing in. Is there any way to disable or change the password? I cannot find a default password for this. I have attached the screen shots for your reference.
Software version is
sip6821.12-0-5MPP0102-328.loads
Vaijanath Sonvane
Hi @Don Jaya,
Are you able to check below process from 6800 series phone guide:
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Vaijanath Sonvane
Hi @Don Jaya,
Hi @Vaijanath Sonvane ,
Thanks a lot. This works. Just something to note each time the phone reboots, I am required to enter the password to gain access to the phone's features. But after that no need to sign in.
Vaijanath Sonvane
@Don Jaya, Glad your issue is resolved. And thank you for additional notes.
