Cisco 7841 - Can I use a Line Button to create a forward all calls to a specific phone number
BrianChernish
I use a Cisco 7841 SIP Desk phone. I would like to create a single button to forward all calls to a specific phone number which I can hit when I leave my desk. Right now I have to use the softkey "FWD ALL" then punch in the 10 digit phone number. I was hoping to use on of my unused line buttons to accomplish this. I would then use "FWD OFF" when I return to my desk?
Does anyone know if this can be accomplished?
Brian
Jaime Valencia
You can't, no way to configure that, best thing you can do is configure the DN as a speed dial so you only need to press CFA + speed dial
java
if this helps, please rate
You can add the 10 digit as a speed dial,so when you leave you need to press the CFwALL and then speed dial button.
But the option which you looking, AFAIK  will not be  possible. The available options to configure on buttons are below mentioned.
Response Signature
