Cisco 7841 firmware upgrade for 3PCC not working
Hello
We just got few cisco 7841 phone. We want to use them with asterix. I tried to flash the firmware sip78xx.10-3-1-11-3PCC.loads but it's not working.
This is the error in the message file on the web .
Could please somebody help me, or let me know how to get this work?
currently the firmware is
App Load ID rootfs78xx.11-5-1-18
Boot Load ID sboot78xx.11-5-1-18
Version sip78xx.11-5-1-18
1133 NOT Jul 28 20:01:56.014954 (1382:1382) TFTPD-pid = 1382
1134 NOT Jul 28 20:01:56.044010 (1382:1382) TFTPD-LIMIT downdload will be limited to 2048 KB
1135 ERR Jul 28 20:01:56.045994 (1382:1382) TFTPD-ai_family = 2, sockType = 2, protocol = 17
1136 NOT Jul 28 20:01:56.049198 (1382:1382) TFTPD-Requesting sip78xx.10-3-1-11-3PCC.loads from 10.250.246.69
1137 WRN Jul 28 20:01:56.049687 (1382:1382) TFTPD-sendto() failed : Address family not supported by protocol
1138 NOT Jul 28 20:01:56.528246 (523:909) JAVA-set gTOS = 0, ret=0, sock=40
1139 NOT Jul 28 20:01:56.528429 (523:909) JAVA-then get tos = 0, socket=40
1140 NOT Jul 28 20:01:56.528643 (523:909) JAVA-set gTOS = 0, ret=0, sock=42
1141 NOT Jul 28 20:01:56.528734 (523:909) JAVA-then get tos = 0, socket=42
1142 NOT Jul 28 20:01:56.552418 (1382:1382) TFTPD-Timeout: retransmit the last packet (1)
1143 NOT Jul 28 20:01:56.557973 (1382:1382) TFTPD-Finished: rcvd 988 bytes
1144 NOT Jul 28 20:01:56.567190 (1360:1360) dgetimage-FORCED-TFTP complete - status = 0
1145 NOT Jul 28 20:01:56.578361 (1360:1360) dgetimage-GETIMG AUTH RAM FILE
1146 ERR Jul 28 20:01:56.578849 (1360:1360) dgetimage-sec_validate_image_file
1147 ERR Jul 28 20:01:56.580253 (1360:1360) dgetimage-sec_validate_image_file Cisco header size (340)
1148 ERR Jul 28 20:01:56.596337 (1360:1360) dgetimage-IMGAUTH_ERROR Verification Failure
1149 NOT Jul 28 20:01:56.603631 (1360:1360) dgetimage-astat = -12, realfname=sip78xx.10-3-1-11-3PCC.loads, buf->offset=0
1150 NOT Jul 28 20:01:56.608515 (1360:1360) dgetimage-GETIMG-DEBUG auth astat:[-12], VFY_SUCCESS:0
1151 NOT Jul 28 20:01:56.608972 (1360:1360) dgetimage-GETIMG: astat: -12, buf->status:244, VFY_SUCCESS:0
1152 NOT Jul 28 20:01:56.609400 (1360:1360) dgetimage-GETIMG: returned with 244
1153 NOT Jul 28 20:01:56.610560 (1347:1347) img-nopfs-&&&done dd_get_image_ replies 244
1154 ERR Jul 28 20:01:56.610743 (1347:1347) img-nopfs-LOAD6 [offset:-244] downdload image file failure.
1155 NOT Jul 28 20:01:56.706546 (1360:1360) dgetimage-DDGETIMG.RESULT [Error description unknown]
9 Replies 9
Leo Laohoo
This error message tells me the firmware is corrupt.
Try downloading the standard SIP files (in ZIP) and use that.
Hi Leo
I download the firmware directly from https://software.cisco.com/download/release.html?mdfid=284892536&reltype=all&relind=AVAILABLE&dwnld=true&softwareid=282074288&rellifecycle=&atcFlag=N&release=10.3(1.11)%203rd%20Party&dwldImageGuid=B736B51892800CD791E9F71A5B9953FF41112FA4&flowid=46503
and unzipped it to the tftp directory.
It was working for firmware 11 and also for 11.5 but 10.3 for third party is not working. I do not know how otherwise setup the phone to be used with asterisk.
Search in this forum.  I've already helped a few people how to do this.
thanks I will do so , hovewer can we please go back to the issue with the firmware? Is there any way of help?
thank you
Same as before.  I've helped some people with this too.
You will need the following:
1.  The firmware of the phone (ZIP file);
2.  SEPmacaddress.xml.cnf;
3.  DHCP Option 150; and
4.  TFTP server
|I have all this.
I downloaded the firmware and unzipped it.
I setup the tftp ip address manually on the phone to my tftp server.
I created the XMLDefault.cnf.xml
<Default>
<loadInformation622 model="Cisco 7841">sip78xx.10-3-1-11-3PCC</loadInformation622>
<webAccess>1</webAccess>
<sshAccess>1</sshAccess>
<sshPort>22</sshPort>
</Default>
the firmware is download from cisco website and uzipped. but wont gets loaded
The phone version is 10.X.   XMLDefault.cnf.xml will NOT be used.    I repeat:
4.  TFTP server
the phone version is currently 11.5 not 10.x XMLdefault.cnf.xml is used as I can see that in the tcpdump that it's requesting this file and downloading as well.
Hi Here is the tcpdump
there is clearly written it's getting the xml file. also on the phone I see that the upgrade failed. but I do not know why.
02:23:35.525481 IP 10.250.246.200.52667 > 10.250.246.69.tftp: 27 RRQ "XMLDefault.cnf.xml" octet
02:23:35.525960 IP 10.250.246.69.11952 > 10.250.246.200.52667: UDP, length 199
02:23:35.527193 IP 10.250.246.200.52667 > 10.250.246.69.11952: UDP, length 4
02:23:38.723787 IP 10.250.246.200.50819 > 10.250.246.69.6970: Flags [S], seq 2472810909, win 29200, options [mss 1460,sackOK,TS val 4294957051 ecr 0,nop,wscale 4], length 0
02:23:38.723804 IP 10.250.246.69.6970 > 10.250.246.200.50819: Flags [R.], seq 0, ack 2472810910, win 0, length 0
02:23:39.317007 IP 10.250.246.200.51739 > 10.250.246.69.tftp: 37 RRQ "sip78xx.10-3-1-11-3PCC.loads" octet
02:23:39.317547 IP 10.250.246.69.11952 > 10.250.246.200.51739: UDP, length 516
02:23:39.319192 IP 10.250.246.200.51739 > 10.250.246.69.11952: UDP, length 4
02:23:39.319276 IP 10.250.246.69.11952 > 10.250.246.200.51739: UDP, length 480
02:23:39.320309 IP 10.250.246.200.51739 > 10.250.246.69.11952: UDP, length 4
02:23:39.999861 IP 10.250.246.200.52157 > 10.250.246.69.tftp: 37 RRQ "sip78xx.10-3-1-11-3PCC.loads" octet
02:23:40.000474 IP 10.250.246.69.11952 > 10.250.246.200.52157: UDP, length 516
02:23:40.001338 IP 10.250.246.200.52157 > 10.250.246.69.11952: UDP, length 4
02:23:40.001379 IP 10.250.246.69.11952 > 10.250.246.200.52157: UDP, length 480
02:23:40.002126 IP 10.250.246.200.52157 > 10.250.246.69.11952: UDP, length 4
