analog polycom with CME
Melany Nolan
Hi, I have a polycom connecting to the fxs port of a CME router.
seems like i am not able to initiate conference with that polycom even i have conference resource configured.
I did some research saying only SCCP and MGCP gateway can do?
thanks.
8 Replies 8
Brandon Buffin
The FXS port would need to be SCCP controlled. See the following links for details on the supplementary features offered by SCCP controlled FXS ports as well as a configuration example.
http://www.cisco.com/c/en/us/td/docs/ios/voice/fxs/configuration/guide/15_1/fxs_15_1_cg_book/fxssccpsplmft.html
https://supportforums.cisco.com/document/34826/using-stcapp-make-fxs-port-sccp-phone
Brandon
thanks Brandon, but I wonder how can I configure the DN on it with SCCP?
mine is a cme, not a mgcp gateway.
Use the destination-pattern command on the dial peer. Gateway does not need to run MGCP.
dial-peer voice 3 pots
destination-pattern 1234
service stcapp
port 0/1/0
but we cannot config service stcapp when destination-pattern is configured on a dialpeer, right?
I know how to set it up now, need to configure the mac address and add it as a normal ephone.
but the conference button still not working.
do you think I need to set up the stcapp feature codes or I still miss anything?
thanks.
Configure it as a normal ephone of the type anl
already configured it as a normal ephone, but whenever I pressed the conference button, it just cannot make the second call.
I'm not sure the conference button will work, but you should be able to initiate a conference using the steps in the Supplementary Services doc:
"User in basic call mode presses hookflash to get the first dial tone, then dials an extension number to connect to a second call. When the second call is established, user presses hookflash to get feature tone and then dials #3 to initiate a three-party conference"
