Cisco 7841 SIP Phone
abbaswayanad
HI i am facing issue with Cisco 7841 sip phone we have CME and CUCM we have more locations recently we got 7841 phones. starting there was no issues but now mostly not registering.  The phone always showing in display ( Registering ) only  so any body can help for this issue also i checked the network settings there everything fine IP and TFTP all showing there
7 Replies 7
Anoop Krishnan
Did you try assigning a DN to the SIP phone to register?
Is it configured via DHCP or DNS
Also please provide the CUCM version deatils.
Anoop
I tried that   also Its configured via DHCP
CUCM Version    10.0.1.10000-24
CME Version  Version 15.4(3)M4,
Hi Abbas,
Were you able to add the phones in CUCM without the help of a device pack or firmware?
If you have already added the device pack earlier, did you upload it in all of your nodes and rebooted them?
If so please check if the IP Phone pulls up Ip address from the correct Vlan.
Also try disabling the DHCP in one of the phone and then manually assign all the IP parameters, such as the IP address, TFTP, DNS, subnet mask, etc. If the IP phone registers fine, the issue is with the DHCP server. You need to check the DHCP server configuration in order to resolve this issue.
Also have the check on your licenses, even you can try a factory reset of a single phone and check
Anoop
HI Anoop phone pulls up Ip address from the correct Vlan no issue
also i did static ip and dns tftp everything ok
we have enogh license   also i did factory reset but issue the same
XML error ( 4 ) parse error.  this message showing on the display
It appears a case of Bug to me, please do search in Cisco Bug Search Tool, also try to raise a TAC and check if it's related.
Also try uploading the latest firmware release from cisco then try to re-register the phone.
Anoop
Thank you Anoop
Look out for the following bug:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuq96598/?reffering_site=dumpcr
Please mark correct and rate if helpful.
Hitesh
