Cisco 7937G Phone not Registering
mcoroghidaf
My cisco 7939 phone is not registering on my CUCM6.0.1, I have installed the device update for 6.0 and the lastest device firmware for 7937G yet, i cannot find the new firmware in the firmware load information and the device default/phone button template for 7937G is also not available.
The implication of this is that the phone is not registering even when it eventually get registered with my SRST Router i cannot use it for voice conferencing because i dont have a suitable phone template fot it.
Any suggestion on way forward will be appreciated.
Rob Huffman
Hi there,
The  7937G is supported in CCM 6.0(1) with the Device Pack  (cmterm-devicepack6.0.1.2111-1 or later ) listed below. Once these upgrades are done the  7937 will be added to the available "Add a new Phone" selections (and  Device Defaults Page). Don't forget that when installing a new Device pack a cluster-wide reboot is required
Compatible Cisco Unified CallManager Release -  7937G
4.1(3)SR5
ciscocm.4-1-DevPack-59  or later
4.2(3)SR2
ciscocm.4-2-3-DevPack-36 or later
4.3(1)
ciscocm.4-3-1-DevPack-16  or later
5.1(2)
cmterm-devicepack5.1.2.3111-1 or later
5.1(3)
cmterm-devicepack5.1.3.1104  or later
6.0(1)
6.1
No device pack  required, native support
From the Cisco Unified IP Conference Station 7937G  Firmware Version 1.1(1) - ReadMe;
http://download-sj.cisco.com/cisco/voice/ip-7900ser/cmterm-7937-sccp.1-1-1-readme.htm
Hope  this helps!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
7 Replies 7
Rob Huffman
Hi there,
4.1(3)SR5
4.2(3)SR2
4.3(1)
5.1(2)
5.1(3)
6.0(1)
6.1
Hope  this helps!
Rob
I had to go for a lower version of the device upgrade pack and after that the phones registered.
i now noticed another issue they now switch between my SRST Router and CUCM!
any idea how to solve this?
any response will be appreciated.
Dafe Oroghi.
Kindly ensure that Cisco 7937 registers in access VLAN unlike all other Cisco phones which register in voice VLAN. If you have configured the corresponding switchport in voice vlan, configure it in access vlan.
I did a debug on the phone and dicovered that it is showing an error 'can't resolve 'server' name' so, what i did is to enter the server name in the url and after that all the 7937G phones registered to the call manager.
Thanks for the contribution!
I most say i appreciate all the contributions.
regards,
dafe.
        i'm with the same issue. I verified the network configuration from IP Station and all IPs address (cm1, cm2, srst, ip, mask, default gatway, id vlan, tftp, dns1, dns2, domain name) are right. I would  to know wich server do you configured manualy.
Thank you.
Hi f.cestari,
The issues were much and its quite some time but the solution as far
as the 7937 phones were concerned are: 1. at some point the
callmanager does firmware doesnot have support for the model so we had
to download the image and upload it to the cm.
2. The IP address on one of the 7937 was conflicting with the SVI IP
address of the voice VLAN.
3. Misteriously one of the phones was not talking to the tftp server
configured in the option 150, so we had to manually configure the ip
address in the network settings of the CallManager.
I hope this will be helpful.
Dafe Oroghi.
I know this is a really old post but I recently took over a system that had this issue and is now resolved.
