07-09-2013 02:41 AM - edited 03-16-2019 06:17 PM
I have a Cisco 7942 phone which is not booting.
After connecting the PoE network cable to the phone these buttons are on
- mailbox (at the handset), both line buttons, headset, mute, speaker
Then all these buttons goes off and only the speaker LED is on and in the display nothing is displayed.
I already tried to make a factory reset which is not working.
What can I do to make this Cisco 7942 working again?
BR
Michael
07-16-2013 01:45 AM
Hi Rudolf,
so you also don`t have any solution for this problem correct?
Or did you get any other suggestions from your frient working at Cisco?
BR
Michael
07-16-2013 01:54 AM
Hello Michael,
My friend also suggest me to perform RMA with Cisco because he has same exprience before with 20+ new phone in problem. But in my case, because my phones were expired maintenance, I've no way to apply RMA.
BTW, I'm going to build up a CME for try another call manager for last chance. Will update you the result here and see if I'm luck.
Best regards,
Rudolf
07-18-2018 05:30 AM
how to bypass speaker light.
Hai Nguyen
11-20-2018 02:52 PM
Worked for me!
11-06-2014 07:55 AM
Had the same issue and just found this Field Notice:
http://www.cisco.com/c/en/us/support/docs/field-notices/637/fn63772.html
