07-08-2015 02:11 AM - edited 03-17-2019 03:34 AM
One of my customers have 7945 cisco phones.
They spontaneously go into upgrading modes, this happens 3 maybe 4 times a day.
And after a while all the phones are registering normally.
I didnt find out why this happens, i checked the firmware
All the phones are using firmware SCCP45.9-2-1S
I gave the customer instructions to execute factory reset 123456789*0#
This didnt work.
They also tried a cisco hard reset ( 3491672850*#)
This also didnt work.
The phones are still upgading dont know how to fix this.
What can be done to solve this problem, any help would be appreciated.
07-08-2015 03:25 AM
Hi.
Please try to load 9.3.1(SR4) firmware version and observe the behaviour.
If the issue seems fixed, then proceed with the upgrade to version 9.4.2(SR1)
Carlo
07-08-2015 04:03 AM
Hi carlo i tried it, unfortunately it didnt work:
I've used this procedure:
https://supportforums.cisco.com/document/9873946/upgrade-downgrade-firmware-specific-ip-phone
After i finished i have restarted tftp server.
07-08-2015 04:26 AM
Hi Mohamed.
you mean that the downgrade didn't work or after downgrade the phone is still rebooting?
Please also mention CUCM version your customer is running.
Cheers
Carlo
07-08-2015 05:01 AM
Carlo,
All the phones have status: unregistered
Active load: SCCP45.9-2-1S
I'm not downgrading, i'm trying to upgrade the firmware with :SCCP45.9-3-1SR4-1S
I'm doing this because the phones are still showing upgrading
System version of cucm is : 9.1.2.10000-28
07-08-2015 05:01 AM
Hi Mohamed,
Can you provide console logs from one of the phone.
JB
07-08-2015 05:22 AM
I'm not able to, because the customer is in Lagos.
I work in the netherlands.
Is there a way to do this?
07-08-2015 05:26 AM
As log as the phone has an address and the web access to the phone is not disable, you should be able to get the console logs. also make sure HTTP traffic is not blocked from your PC to the phone.
JB
07-08-2015 07:51 AM
i was able to capture some console logs
it saying tftp timeout
also i see its trying to retrieve ringtone etc..
07-08-2015 07:56 AM
Can you attach them to the discussion for us to have a look.
JB
07-08-2015 08:02 AM
I'll get back on this tomorrow, tnx for your patience
07-09-2015 01:03 AM
Hi Jitender,
I've just attached 3 log files.
Take a loot at the first post .
07-09-2015 05:22 AM
Could be possible issue with the SEP file or download.
9079: WRN 04:58:32.236574 JVM: Startup Module Loader|cip.xml.ap:parse - Encoding Updated to UTF-8
9080: WRN 04:58:32.238180 JVM: Startup Module Loader|cip.xml.ap: - XML Parser Warning: Unknown element 'mlppDomainId' in element '/device' (line=14)
9081: WRN 04:58:32.239845 JVM: Startup Module Loader|cip.xml.ap: - XML Parser Warning: Unknown element 'mlppIndicationStatus' in element '/device' (line=15)
9082: WRN 04:58:32.242144 JVM: Startup Module Loader|cip.xml.ap: - XML Parser Warning: Unknown element 'preemption' in element '/device' (line=16)
9083: WRN 04:58:32.243777 JVM: Startup Module Loader|cip.xml.ap: - XML Parser Warning: Unknown element 'executiveOverridePreemptable' in element '/device' (line=17)
9084: WRN 04:58:32.245467 JVM: Startup Module Loader|cip.xml.ap: - XML Parser Warning: Unknown element 'name' in element '/device/devicePool' (line=20)
9085: WRN 04:58:32.247087 JVM: Startup Module Loader|cip.xml.ap: - XML Parser Warning: Unknown element 'name' in element '/device/devicePool/dateTimeSetting' (line=22)
9086: WRN 04:58:32.248773 JVM: Startup Module Loader|cip.xml.ap: - XML Parser Warning: Unknown element 'name' in element '/device/devicePool/callManagerGroup' (line=28)
9087: WRN 04:58:32.250560 JVM: Startup Module Loader|cip.xml.ap: - XML Parser Warning: Unknown element 'tftpDefault' in element '/device/devicePool/callManagerGroup' (line=29)
9088: WRN 04:58:32.252205 JVM: Startup Module Loader|cip.xml.ap: - XML Parser Warning: Unknown element 'mgcpPorts' in element '/device/devicePool/callManagerGroup/members/member/callManager/ports' (line=39)
9089: WRN 04:58:32.253910 JVM: Startup Module Loader|cip.xml.ap: - XML Parser Warning: Unknown element 'mgcpPorts' in element '/device/devicePool/callManagerGroup/members/member/callManager/ports' (line=55)
9090: WRN 04:58:32.255615 JVM: Startup Module Loader|cip.xml.ap: - XML Parser Warning: Unknown element 'mgcpPorts' in element '/device/devicePool/callManagerGroup/members/member/callManager/ports' (line=71)
9091: WRN 04:58:32.257259 JVM: Startup Module Loader|cip.xml.ap: - XML Parser Warning: Unknown element 'name' in element '/device/devicePool/srstInfo' (line=82)
9092: WRN 04:58:32.258903 JVM: Startup Module Loader|cip.xml.ap: - XML Parser Warning: Unknown element 'userModifiable' in element '/device/devicePool/srstInfo' (line=84)
9093: WRN 04:58:32.261395 JVM: Startup Module Loader|cip.xml.ap: - XML Parser Warning: Unknown element 'headsetRecording' in element '/device/vendorConfig' (line=125)
9094: WRN 04:58:32.262998 JVM: Startup Module Loader|cip.xml.ap: - XML Parser Warning: Unknown element 'RingLocale' in element '/device/commonConfig' (line=127)
9095: WRN 04:58:32.264614 JVM: Startup Module Loader|cip.xml.ap: - XML Parser Warning: Unknown element 'instantMessaging' in element '/device/commonConfig' (line=127)
9096: WRN 04:58:32.266257 JVM: Startup Module Loader|cip.xml.ap: - XML Parser Warning: Unknown element 'desktopClient' in element '/device/commonConfig' (line=127)
9097: WRN 04:58:32.267833 JVM: Startup Module Loader|cip.xml.ap: - XML Parser Warning: Unknown element 'uid' in element '/device/networkLocaleInfo' (line=141)
9098: WRN 04:58:32.269406 JVM: Startup Module Loader|cip.xml.ap: - XML Parser Warning: Unknown element 'mobility' in element '/device' (line=181)
9099: WRN 04:58:32.271094 JVM: Startup Module Loader|cip.xml.ap: - XML Parser Warning: Unknown attribute 'serviceProfileFile' in element '/device/userId'
Are there phones local to CUCM.
can you try to rebuild CNF file and restart TFTP and then check.
JB
07-09-2015 06:44 AM
create cnf files?
Its cucm based not cme.
I've also restarted tftp yesterday howe ever no luck.
What exactly do you mean with "are there phones local to cucm"
07-09-2015 07:13 AM
I said rebuild CNF file not create, in order to rebuild CNF files on CUCM you can go to System -> Service Parameter >> Select a server >> select TFTP click on advance button on top
Make the below change
Build CNF Files >> Build All
Enable Caching of Constant and Bin Files at Startup >> False
Exit When Exception is Caught >> False
Save it and restart TFTP on all servers wait for about 15 min and the Revert them back to default and restart TFTP again.
And going forward if i am seeking for assistance i should not put sarcastic comment like this is CUCM not CME.
JB
