Cisco 7945
Can I forward all calls to a cell phone? If so how.
Jitender Bhandari
Hi sammy
go to the DN page and under "Forward All" put the Cell number assign a CSS which has access to RP to dial your cell phone.
JB
Jaime Valencia
Assuming the phone is registered to a Cisco Call Control agent, just press the CFA on the phone and dial the number you want to forward to, in the format it would be required by your dial plan.
java
if this helps, please rate
