Cisco 7945G Rebooting while trying to upgrade
RCBA_ADMIN
Hi to all,
I have a Cisco 7945g a friend gave me as he gave up trying to upgrade it so now its my go
I have a tftp server setup as a dhcp server and the phone connects directly to the computer
I am upgrading the phone to sip firmware 8.5.2 unfortunately I do not know what version it is currently on all I know is it is currently using SCCP
What happens is the phone connects fine, gets the ip address then starts to download the term45 file and then just reboots
Not sure why hopefully you guys know
14 Replies 14
  1. Unplug Ethernet & power cable (if applicable) from the back of the phone.
  2. Press and hold the # (Pound/Hashtag) key and plug the Ethernet & power cable back in.
    *****Note: Once the Headset, Mute & Speaker buttons flash in sequence it is safe to release the # (Pound/Hashtag) key and promptly enter the reset key sequence​​​​
  3. Press in order 123456789*0# to begin the reset sequence.
Reset the phone using above steps and try to load the firmware.
Response Signature
Unfortunately it just comes back up with the upgrade screen
RCBA_ADMIN
Heres what it is doing
I hope your upgrade file is on your laptop. So run TFTP applications on your laptop and keep the firmware files on the TFTP folder and on DHCP configure option 150 as your Laptops IP address.
Use ZIP firmware File.
Response Signature
Just to upgrade it I have the ethernet cable coming out of my computer and connected directly to the phone no switch or anything else
then the tftp server acts as a temporary dhcp server
You need a DHCp server and configure option 150 IP as your laptop IP. without that phone won't take the new firmware.
Response Signature
How would I do that?
You need a switch.
Put the phone and pc on same Vlan
Configure DHCp pool With option 150 as your Laptop IP address.
Run TFTP application on your laptop and keep the Firmware files on the TFTP folder.
Response Signature
The computer and the phone are not connected to a network
the cable comes out of the computer and into the phone and that connects them
The phone need an IP and TFTP address either statically configured or by DHCP. With out the TFTP address information the phones is not going to download  the firmware.
You cant make this   working just by connecting the phone to your computer.
Response Signature
The TFTP application replicates a dhcp server the phone is allocated a ip address by the tftp server
The phone is getting a ip address
Scott Leport
Level 7
Level 7
Unless I missed it, it may help telling us what you're trying to register your phone to. Is it CUCM or CME?
I am trying to connect to a sip pbx system but right now I am just trying to update it
The phone starts downloading files the reboots almost immediately
