08-09-2014 10:42 AM - edited 03-16-2019 11:41 PM
CIsco 7960 IP Phone was upgraded firmware from sccp to sip. It has taken firmware correctly but not registering with CME on the local router. I configured Voice register global, voice register dn, voice register pool. All phones are taking extention numbers configured 5000, 5001, 5002. But not registering with CME so that I can make internal calls each other. when I reload CME router, phones are not reloading itself. All phones have taken IP from DHCP pool and even extensions but not registered.
Please suggest me configuration to register phones with CME. Do I need to register it to sip registrar server to make call on other extendions on the same LAN?
Status Message On IP 7960 Phone:
W310 12 error(s) Parsing
SIPDefault.cnf
W320 5 error Parsing
SIPP0002B9AFC0F7.cnf
W360 no DNS server Active
E600 REG send failure
REGISTER
E102 MISC Error: No Time
server
W350 invalid proxy_backup
W351 invalid proxy_emergency
CME# sh voice register pool all
Pool Tag 1
Config:
Mac address is 0003.6B54.BCD9
Type is 7960
Number list 1 : DN 1
Proxy Ip address is 0.0.0.0
DTMF Relay is disabled
Call Waiting is enabled
DnD is disabled
Video is disabled
Camera is disabled
Busy trigger per button value is 0
keep-conference is enabled
registration expires timer max is 600 and min is 60
username redoq password redoq123
dialplan tag is 1
Lpcor Type is none
blf call list is enabled
Transport type is udp
service-control mechanism is not supported
Registration method: per line
Privacy feature is not configured.
Privacy button is disabled
Reason for unregistered state:
No registration request since last reboot/unregister
Dialpeers created:
Statistics:
Active registrations : 0
Total SIP phones registered: 0
Total Registration Statistics
Registration requests : 0
Registration success : 0
Registration failed : 0
unRegister requests : 0
unRegister success : 0
unRegister failed : 0
Attempts to register
after last unregister : 0
Last register request time :
Last unregister request time :
Register success time :
Unregister success time :
Pool Tag 2
Config:
Mac address is 0030.94C4.5009
Type is 7960
Number list 1 : DN 2
DnD is disabled
Video is disabled
Camera is disabled
username redoq1 password redoq123
dialplan tag is 1
Lpcor Type is none
Dialpeers created:
Statistics:
Pool Tag 3
Config:
Mac address is 0002.B9AF.C0F7
Type is 7960
Number list 1 : DN 3
DnD is disabled
Video is disabled
--More-- Camera is disabled
username redoq2 password redoq123
dialplan tag is 1
Lpcor Type is none
Dialpeers created:
Statistics:
RedoqCME(config)#voice register global
RedoqCME(config-register-global)#reset
No contact info available for pool 1.
No contact info available for pool 2.
No contact info available for pool 3.
No contact info available for pool 4.
RedoqCME(config-register-global)#^Z
RedoqCME#sh run
Building configuration...
Current configuration : 9361 bytes
! Last configuration change at 17:04:55 UTC Sat Aug 9 2014 by redoq
! NVRAM config last updated at 14:46:12 UTC Sat Aug 9 2014
version 15.1
hostname RedoqCME
boot-start-marker
boot-end-marker
no aaa new-model
network-clock-participate wic 0
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 10.10.1.1 10.10.1.10
ip dhcp excluded-address 10.15.1.1 10.15.1.10
ip dhcp pool DATA
network 10.10.1.0 255.255.255.0
default-router 10.10.1.1
ip dhcp pool VOICE
network 10.15.1.0 255.255.255.0
default-router 10.15.1.1
option 150 ip 10.15.1.1
isdn switch-type basic-net3
trunk group ext
voice-card 0
codec complexity high
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
h225 timeout ntf 500
call preserve
h245 caps mode restricted
modem passthrough nse codec g711ulaw
sip
registrar server expires max 600 min 60
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class h323 1
h225 timeout tcp establish 3
mode cme
source-address 10.15.1.1 port 5060
max-dn 20
max-pool 10
load 7960-7940 P0S3-07-5-00
call-forward system redirecting-expanded
tftp-path flash:
create profile sync 000164329254815A
network-locale GB
network-locale 1 GB
network-locale 2 GB
voice register dn 1
number 5000
name SIP 1
allow watch
voice register dn 2
number 5001
allow watch
name SIP 2
voice register dn 3
number 5002
allow watch
name SIP 3
voice register dn 4
number 5003
allow watch
name SIP 4
voice register dialplan 1
type 7940-7960-others
pattern 1 5...
pattern 2 5000
pattern 3 5001
pattern 4 5002
pattern 5 5003
voice register dialplan 2
pattern 2 01782......
voice register pool 1
id mac 0003.6B54.BCD9
type 7960
number 1 dn 1
dialplan 1
presence call-list
codec g711ulaw
voice register pool 2
id mac 0030.94C4.5009
type 7960
number 1 dn 2
dialplan 1
voice register pool 3
id mac 0002.B9AF.C0F7
type 7960
number 1 dn 3
dialplan 1
voice register pool 4
id mac 0003.6B75.A91C
type 7960
number 1 dn 4
dialplan 1
voice hunt-group 1 sequential
final 5003
list 5000,5001,5002
timeout 20
pilot 5900
license udi pid CISCO2911/K9 sn xxxxxxxxxxxxxxx
license boot module c2900 technology-package securityk9
license boot module c2900 technology-package uck9
license boot module c2900 technology-package datak9
hw-module pvdm 0/0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 1.1.1.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.1
encapsulation dot1Q 1
ip address 10.1.1.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.10
encapsulation dot1Q 10 native
ip address 10.10.1.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.15
encapsulation dot1Q 15
ip address 10.15.1.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
router eigrp 100
network 10.0.0.0
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 36000 requests 10000
ip http path flash:gui
tftp-server flash:P0S3-07-5-00.bin
tftp-server flash:P0S3-07-5-00.loads
tftp-server flash:P0S3-07-5-00.sb2
tftp-server flash:P003-07-5-00.sbn
tftp-server flash:OS79XX.TXT
control-plane
voice-port 0/0/0
input gain 4
compand-type a-law
cptone GB
timeouts call-disconnect 5
timeouts wait-release 5
connection plar 5900
bearer-cap Speech
voice-port 0/0/1
input gain 4
compand-type a-law
cptone GB
bearer-cap Speech
voice-port 0/2/0
supervisory disconnect dualtone pre-connect
supervisory answer dualtone sensitivity high
no battery-reversal
soft-offhook
input gain 4
cptone GB
connection plar opx 5000
impedance complex2
bearer-cap Speech
caller-id enable
mgcp profile default
presence
presence call-list
sip-ua
gatekeeper
shutdown
line con 0
password ********
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
exec-timeout 0 0
privilege level 15
password *******
logging synchronous
login local
transport input all
transport output all
scheduler allocate 20000 1000
end
08-11-2014 12:17 PM
Hi Suresh,
I have already done these steps. It still showing same. no registration request.
08-12-2014 11:40 PM
I got solution. There was no issue with configuration on router. It was compatibility issue of firmware and CME versions. CME 7.1 loaded in this c2900 router is not compatible for SIP. It does work fine for SCCP.
Compatible plateform, software for CME7.0:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme71spc.html
Compatible plateform, firmware, software for CME8.6:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme86spc-htm.html
Thank You for all your support guys.
08-13-2014 01:29 AM
oh i thought you are running CME 8.6, i saw that in your "sh voice register global".
isnt it?
anyways glad it worked, +5 for sharing the resolution.
regards
Chintan
08-13-2014 05:57 PM
