Cisco 7960 upgrade to SIP issues
Hi All,
I have been trying to upgrade Cisco 7960G phone from SCCP to SIP for some time now without luck.
First of all, I cannot find an "unlock phone" option on my 7960G phone so I can't erase the existing configuration.
There is no password set up. When I go to Settings, there are only 6 sections - last one is Security Config. CTL is not installed
I reboot SCCP phone, keep # pressed, go through 12345.... sequence, choose No.
The phone is not picking up new firmware from TFTP/CME
SIP P0S3-8-12-00
SCCP P0030801SR02- currently installed on the phone
Do I need to do a staged upgrade to this version of SIP?
Ping works between CME and IP phone.
Hope that somebody an help !
My lab set-up:
CME: version 8.1
192.168.100.254 VLAN 100
acts as TFTP/DHCP server
PoE Switch 3560
acts as router/gateway
192.168.100.253 VLAN 100
192.168.10.253 VLAN 10
Voice VLAN 10
192.168.10.0/24
Switch show run
Current configuration : 1622 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname SW-3560
ip subnet-zero
ip routing
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
switchport access vlan 100
descr CME RTR
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
switchport mode access
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
switchport voice vlan 10
spanning-tree portfast
descr phone-1-sccp
interface FastEthernet0/14
shutdown
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
interface Vlan10
ip address 192.168.10.253 255.255.255.0
ip helper-address 192.168.100.254
interface Vlan100
ip address 192.168.100.253 255.255.255.0
ip classless
ip http server
CME Router "show run"
Current configuration : 1966 bytes
! Last configuration change at 11:20:08 E Sat Sep 24 2016
version 15.1
hostname RTR-VOICE2
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/2
no aaa new-model
clock timezone E 0 0
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 192.168.10.250 192.168.10.254
ip dhcp pool VOIP-POOL
   network 192.168.10.0 255.255.255.0
   option 150 ip 192.168.100.254
   default-router 192.168.10.253
no ip domain lookup
no ipv6 cef
voice service voip
 allow-connections h323 to sip
 allow-connections sip to sip
 sip
  registrar server expires max 600 min 60
voice register global
 mode cme
 source-address 192.168.100.254 port 5060
 max-dn 20
 max-pool 2
 load 7960-7940 P0S3-8-12-00
 tftp-path flash:
 create profile sync 0001596893951857
voice register dn  1
 number 2001
voice register pool  1
 id mac 0021.5502.9014
 type 7960
 number 1 dn 1
 description problemPhone
 codec g711ulaw
voice-card 0
license udi pid CISCO2811 sn FCZ15047EUR
license accept end user agreement
redundancy
interface FastEthernet0/0
 ip address 192.168.100.254 255.255.255.0
 duplex auto
 speed auto
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 192.168.10.0 255.255.255.0 192.168.100.253
logging esm config
tftp-server flash:P0S3-8-12-00.loads
tftp-server flash:P0S3-8-12-00.sbn
control-plane
gatekeeper
 shutdown
line con 0
 exec-timeout 0 0
 logging synchronous
line aux 0
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
ntp master
ntp server 192.168.100.254
end
CME show voice register tftp-bind
RTR-VOICE2#show voice register tftp-bind
tftp-server syncinfo.xml url flash:/syncinfo.xml
tftp-server SIPDefault.cnf url flash:/SIPDefault.cnf
tftp-server softkeyDefault_kpml.xml url flash:/softkeyDefault_kpml.xml
tftp-server softkeyDefault.xml url flash:/softkeyDefault.xml
tftp-server SIP002155029014.cnf url flash:/SIP002155029014.cnf
Aseem Anand
To unlock the phone you need to press the settings button and then press **#.
Aseem
Hi Aseem,
Nothing happened. I tried that already!
I managed to sort it yesterday by configuring CUCM VM and the phone has picked up correct firmware almost instantly.
Thanks for your help
Aseem Anand
You may refer to the link below:
http://www.cisco.com/c/en/us/support/docs/collaboration-endpoints/unified-ip-phone-7900-series/5455-handset-to-sip.html#sccptosip2
Aseem
