Cisco 7962G - SIP configuration files
lizakpawel
Where can i find sip configuration files? I do not have any cisco contract, i just bought this phone and try to configure it.
I know how to edit them and transfer to terminal, but i do not have any samples.
Does anybody can help me with any samples files?
Thank you in advance
5 Replies 5
Leo Laohoo
Have you tried searching this forum?
I have helped so many and the file can (still) be found if some- or anyone takes the time to search.
lizakpawel
Hi Thanks for replay, yes i found for 7960 tried but terminal give error seams 7962g need other files
For 7960: SIPmac and sipDefault
but 7962g need: XMLDefault and SEPmac
Just search for the files in this forum, OK?  Just try, because the above statement is already wrong.
Yes I did i read all topics with written 7962G.
I am not looking for firmware which is on cisco server but for configuration SIP files which are not there.
Maybe you wrote to look for about "copy 9970.zip" yes i got it.
So please if i am wrong can you past me in which topic? Maybe you have other privileges and you see more than me
If the phone is running 9.X.X you will only need the following:
  1. A working SEPmacaddress.cnf.xml file;
  2. A dial plan file;
  3. Firmware of the phone
