CUCM minor upgrade from 11.5.1SU2 to SU7 failed
Yangjp715
Level 2
Level 2
Hi all,
Seems i hit a Cisco bug during CUCM minor upgrade from 11.5.1 SU2 to SU7. The upgrade for the PUB is success (have not switched to the new version), but the SUBs are not. The install log is attached.
What you can see in > file tail install system-history.log  ?
admin:file tail install system-history.log
03/25/2021 00:12:32 | root: Restart 11.5.1.12900-21 Start
03/25/2021 00:13:04 | root: Boot 11.5.1.12900-21 Start
03/25/2021 00:21:15 | root: Upgrade 11.5.1.17900-52 Start
03/25/2021 00:43:45 | root: Upgrade 11.5.1.17900-52 Failure
03/25/2021 12:53:10 | root: Cisco Option Install ciscocm.CSCvv21530-upgrade-fix_C0074-v1.cop Start
03/25/2021 12:53:10 | root: Cisco Option Install ciscocm.CSCvv21530-upgrade-fix_C0074-v1.cop Success
03/25/2021 12:56:30 | root: Restart 11.5.1.12900-21 Start
03/25/2021 12:57:01 | root: Boot 11.5.1.12900-21 Start
03/25/2021 13:07:08 | root: Upgrade 11.5.1.17900-52 Start
03/25/2021 13:29:44 | root: Upgrade 11.5.1.17900-52 Failure
Yangjp715
Level 2
Level 2
Reinstalled the SUB and performed the upgrade via OS admin, but it is still the same.
If not already done I would recommend you to reach out to TAC for help on this.
Response Signature
