Cisco 7962g
Al Abdulla
Does anyone know if a 7962g supports tlsV1.2 for connecting as a VPN phone, or do I need to upgrade the firmware or phone model?
If it does support tlsV.12 how do I force it to use it, instead of tlsV1?
My current firmware is SCCP42.9-3-1-1S, CUCM is on 8.6.2.21900-5
ASA: 5545 - 9.5(2)
Al
Manish Gogna
Hi Al,
78xx and the 88xx phones support TLS 1.2 on firmware versions 10.3.1 and newer.
Manish
Hi Manish,
Thank you for the response, can I take it from your answer that the 7962g (yes i know they are EoS, EoL) do not support tlsv1.2?
Al
That's what I could find from an internal reference, if you have a large deployment you may get a confirmation from TAC.
Manish
Gordon Ross
Level 9
Level 9
The 7942 & 7962 have a ASA AnyConnect client in them.
I'm not sure of the exact specs of that client, though.
GTG
Please rate all helpful posts.
