Cisco 8821 deployment guide for CME
AntonyB93
Hey, everybody,
I'm going to deploy cisco 8821 wireless phone on CME. I would like to know if it's possible to find any configuration/deployment guide for this combination? All I'm able to find is deployment of 8821 on CUCM, but nothing for CME. Maybe somebody could help me with this case?
8821 is supported in fast track mode on CME 10.5, check below.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme105spc.html
Sample configuration to register using Fast Track method:
voice register pool-type  8821
phoneload-support
reference-pooltype 9971
voice register dn  10
number 8000
voice register pool  10
id mac 1111.2222.3333 [ Mac address of the phone ]
type 8821
number 1 dn 10
username cisco password cisco
voice register global
  create profile
JB
13 Replies 13
Jitender Bhandari
Can you past "show telephony" from your CME.
JB
You need this part?
CONFIG (Version=10.5)
Version 10.5
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
phoneload-support
number 8000
type 8821
number 1 dn 10
  create profile
JB
Thank you so much. This will be really helpful. By the way. What if I would use higher version of CME (11; 11,5 for example)? Would I have to change anything on your configuration?
If you upgrade CEM to 11, 11,5 you dont have to use Fast Track method any more, you can configure it like other SIP native endpoints.
http://www.cisco.com/c/en/us/products/collateral/unified-communications/unified-communications-manager-express/datasheet-c78-737647.html
JB
Thank you one more time!
Happy to help,
You can mark the post as answered if you dont have further questions.
JB
Hi for all , I have CME 11.6 with  wireless Ip phone 8821 firmware version 11.0 .
they are registered normally but transfer button is not showing even I created sofkeys template
please advise , thank you
Just an update on this comment, per the compatibility matrix CME 11 and 11.5 supports IP Phones 8821 but still only on Fast Track Mode:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme115spc.html
Hello.
Can you please explain what this number 9971 refers to, what it actually is?
Thank you.
R0g22
This is part of CME Fast track config to support non-native phones on earlier CME releases. The 9971 here is the phone model based off which you are creating a reference pool.
Hi Jitender,
I have one 8821 working fine one CME 10.5 with username cisco password cisco but few days ago I bought another 8821 and can't find phone username. this time is not cisco.
How can I found out phone username?
Thank you.
migilles
