Cisco 8831 phone showing FAC in clear text during call setup.
tacl75
Recently we have deployed Cisco 8831 conference phone registered to CUCM 8.6.2 and realised that this phone is showing clear text on FAC during call setup. Once the call is connected, the display is back to normal.
Anyway to hide or encrypt the FAC on the phone display during call setup? Any advise will be appreciated. Thanks.
Sample FAC display
Aman Soi
Check this bug if it helps.
8831 Phone: Force Authorization Key is displaying on dial screen
CSCuo97487
Symptom:
Force Authorization key is displayed on dial screen and also in Call History. if you redial the same number from call history then call number includes the FAC number followed by originally called number
Conditions:
Phone Model: 8831
Firmware:sip8831.9-3-3-5
Workaround:
None
Further Problem Description:
In the logs also we can clearly see the FAC code :
REFER message to phone And FAC Code is 91000
00005579.001 |21:06:39.377 |AppInfo |SIPTcp - wait_SdlSPISignal: Outgoing SIP TCP message to 10.106.86.21 on port 46223 index 3
[102,NET]
REFER sip:2341@10.106.86.21:46223 SIP/2.0
Via: SIP/2.0/TCP 10.106.86.3:5060;branch=z9hG4bKc7a46e5e4
To: <2341>
Call-ID: 38e22300-35912f87-c-3566a0a@10.106.86.3
CSeq: 101 REFER
Max-Forwards: 70
Contact: <2341>
User-Agent: Cisco-CUCM9.1
Expires: 0
Refer-To: cid:1234567890@10.106.86.3
Content-Id: <1234567890@10.106.86.3>
Require: norefersub
Content-Type: application/x-cisco-remotecc-request+xml
Referred-By: <2341>
Content-Length: 406
ac44f210-01a90003-2fc42845-5ecfd25d@10.106.86.21
33~bd2a60ee-f70c-48a9-a220-244b518bd418-23376738
ac44f21001a900051206aec2-4eeb85a3
91000
true
If i redial the number from Call history we can see the FAC number with called number:
called number: 12345
FAC number:91000
00006368.009 |21:06:57.589 |AppInfo |Digit analysis: match(pi="2", fqcn="2341", cn="2341",plv="5", pss="", TodFilteredPss="", dd="9100012345#",dac="0")
Known Affected Releases:
(1)
9.3(3)
Known Fixed Releases:
(1)
9.3(3)ES5
regds,
Aman Soi
CSCuo97487
Symptom:
Conditions:
Phone Model: 8831
Workaround:
None
[102,NET]
To: <2341>
CSeq: 101 REFER
Max-Forwards: 70
Contact: <2341>
Expires: 0
Require: norefersub
Referred-By: <2341>
Content-Length: 406
91000
true
FAC number:91000
(1)
9.3(3)
(1)
9.3(3)ES5
regds,
Hi Aman,
Any solution on this issue? Is it possible try upgrade to the latest version 8.6.2 SU5 ?
Thanks.
Hi ,
I suggest opening TAC case since fix is available in version 9.3(3)ES5 which u can get only from TAC or take suggestion of TAC whether upgradation of CUCM is the only resolution.
regds,
aman
Hi Aman,
Thanks for your suggestion.
