CISCO 8841
zooman
I am trying to program my sip settings on this phone. It has the sip firmware and Now all I need to do is program my stuff in. Can some please give me direction on how to do this please.
Thank you.
12 Replies 12
Leo Laohoo
More info required. Is this Cisco CUCM/CUE or non-Cisco callmanager. If it's non-Cisco, state the product.
Sorry I'm new to this. This is a non cisco call manager setup. Product is 8841. That is all I have and need to know what I am missing. Thanks
Sample SEPmacaddress.cnf.xml file(s) can be found HERE.
Please don't forget to rate our useful posts.
HI Thanks for the info. When I try to load the file via TFT I get nothing but errors. See the attachment.
The error messages all say the same thing:  Files are not found.
In the default folder of the TFTP client, what files (related to the phone) are there?
Nothing. The only file I have in there is the Sep file that I downloaded from here
To get anywhere with non-Cisco callmanager you'll need to configure or organize the following:
1. Firmware files for the phone;
2. SEMmacaddress.cnf.xml;
3. TFTP server; and
4. DHCP Option 150
Well I have the SEP text
file you had me download
I have the TFTP server installed and running.
DHCP OPTION 66 is what I have as I have a single TFTP server running
Seems I may be missing the Firmware files for the. It was upgraded to Sip and then giving to me
Cisco phones operate with DHCP Option 150.  DHCP Option 66 can be enabled but Cisco phones will completely ignore it.
My TFTP program does not have this option. What TFTP program do you suggest I use.
Also where Can I obtain the firmware files you talked about previously.
Thanks again for all this help. It is much appreciated
Go HERE.
From the owner of the phone
Show your appreciation:  Rate our useful posts.
I am the owner of the phone now. :-)  If i am unable to get the files what else can be done. Can I maybe reload it and take it from there?
