Resolved! Call Manager Roles
I am trying to find out what users have Administrator roles in the Call Manager. How can you list the users and roles?
Hello, Does anybody know about if the wall mount for 7912 phone is compatible with 7811 phone? Thanks, Michael
Is there a way to modify a number based on its Type? For example, I want to prepend '00' to this number before sending it to my users. I want to prepend a single '0' to National Type numbers. Calling Party Number i = 0x1183, '1XXX494XXXX' Plan:IS...
On my Softphone i have 3 lines configure for Location A, B and C When i Send/receive a call from Location A and B, no issue with Hold and Transfer WHeni use line 3 which is for location C, then i am able to put call on hold but unable to retrieve ca...
how many cue ports get used in a call transfer? If a call comes in hits auto attendant, gets transfered to phone extension then to voicemail, how many cue ports get used in the call
Dear Experts; We are trying CME CDR to be sent to a FTP server. I have configured the CME as per the cisco guideline. The cdr by default saving in flash which we dont want and also manually i can copy the cdr file to ftp server but the CDR file ...
Hi Team, I'm facing an issue with 7821 phones. Client had an issue with their NTP on CUCM, which has been fixed and all phones showing correct time except for 3 phones. Tried doing factory reset but didn't resolve the issue. They are connected to the...
Recently purchase serveral 8811 and 8841 handsets to register to broadsoft platform. Both model handset came with what believe is the call manager SIP firmware version (sip88xx.10-3-1-20.loads) however when trying to upgrade the handsets to 3PCC (I t...
We have 1 user whose phone will not forward to voicemail. We have gone line by line over the set up of her phone comparing it to a known good and we can't see any place where the software is incorrect. I am out of ideas. Anyone ever experience thi...
All, working on getting the new licenses but probably won't happen before the expiration date. What will happen if we are a few hundred short? Will Unity stop answering calls for everyone? Thanks in advance! Replies rated.
Hi all. Running CUCM 8.6.1 I have a few expired tomcat-trust certificates. I'm trying to sort through the process of generating new ones, but I'm wondering something: How do I find out which of these certs are actually being used? I assume not the e...
Hi experts,we have an issue that our general number (ex 5200) was noticed to be constantly engaged for about 10mins but only one person is actually engaged in a call. This is a shared number w/ 10 persons as their 2nd line.We checked the CDR and foun...
Hi All, I want to configure the Polycom sound-station 2w conference phone in Cisco Call manager Express. It is a analog sip phone. I have done the SIP configuration for the 3rd party sip phone. But still the device is not up. . CME version: Version...
Dear All, I got two SIP gateways (Pri & Sec) for PSTN calling and I have put them in a route group for redundancy. Requirement: when primary circuit run out of bandwidth I want all calls to route through secondary. Do I need to configure anything her...
friends.. i know i am missing something very stupid .. but i configured a new ISDN BRI on my router .. which already has around 10 lines for 10 different departments coming in and working fine .. i can call any DN from any any dept directly as an ext...
Subject | Author | Posted |
07-17-2025 04:39 AM | ||
07-16-2025 12:00 PM | ||
07-15-2025 06:51 AM | ||
07-09-2025 09:52 AM | ||
07-08-2025 12:50 PM |
User | Count |
4 | |
2 | |
1 | |
1 | |
1 |
