12-18-2015 10:44 AM - edited 03-17-2019 05:17 AM
Hey guys,
I have a Cisco 8865 phone that seems to be having a strange issue. We have used the official instructions in the manual to try and clear out the recent call list using the Application/gear button.
We have also used the 2nd from top right button next to LCD to bring up a secondary recent call list that still showed data in it after above step, and cleared this out as well.
However, when my user picks up the handle or tries to start a new call, a recent call log list appears on the screen that still shows a list of calls. The phone is associated with multiple lines.
I have somewhat ran out of options to fix this on my own and was wondering if this is something you guys may be able to help me with. The only thing I can try right now to see if the issue goes away is to try a factory reset, but wanted to ask the question before taking that kind of step.
12-18-2015 11:52 AM
Hi there,
It sounds like this bug/enhancement perhaps;
Cheers!
Rob
https://tools.cisco.com/bugsearch/bug/CSCut22033
12-18-2015 01:03 PM
Thanks for that update Rob, really appreciate it.
As it turns out, this workaround does not work for this user. She gets the darn recent call list no matter how she tries to start the new call (button or picking up handset). She does not have nor use a headset at this time.
Do you think there are any other options we can try as a workaround for her?
Thank you
