Cisco 8961 - Immediate Divert not available when ringing
Dear all,
iDivert function is not working when my Cisco 8961 phone is ringing.
However, the function is in my softkey template for ringing state. I have only Answer button when ringing.
Do you already encounter this issue?
Sebastien
7 Replies 7
ronpatel
Level 8
Level 8
1-     Go to Device > Device Settings > Feature Control Policy > Hit Add
New.
2-     Name it and on the Feature Control Section select Divert (Alerting)
and Divert (Connected) and enable them > Hit save
3-     Go to Device > Device Settings > Common Phone Profile > Standard
Common Phone Profile > Select the Feature Control Policy that you created.
4-     Go to Device > Phone > Select the phone and make sure that phone has
the Common Phone Profile selected > reset the phone.
Ronak Patel
Please rate helpful posts
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
The button is displaying on the phone but when I press it, I have the message : the key is not active.
HI
What is the version of CUCM and Firmware in IP phone.
Also do you have VM assiciated to this ip phone user.
regards
Ronak Patel
CUCM is 8.0.3.20000-2 and phone firmware is 9.2.3.27.
What do you mean by VM?
Sebastien
HI
" Key is not active" error comes when —The voice-messaging profile of the user who pressed iDivert does not have a
voice-messaging pilot.
What value do you have in "Voice Mail Profile" of the line configuration. Also do you have voice mail setup for this ip phone.
Ronak patel
It works
Thank you
HI
Please rate helpful posts.
Ronak Patel
