Cisco 8961 SIP FAC in clear text
m-laing
I have Cisco Unified Communication Manager 8.0.x in a production environment and I am using FAC with the SIP 8961 endpoint. For outbound calls users are required to enter a FAC, when they do their code is displayed in clear text, Is there a solution to this problem?
Rob Huffman
Hi Marsha,
I believe this is due to a couple of Bug/Defects that do affect the 89xx series as well
CSCta93018            Bug Details
FAC is showing in clear text
Symptom:
While making a call outside through PSTN or Trunk and FAC is compulsary for that Route pattern and User provided the correct FAC. It is showing in clear text.
Conditions:
Workaround:
Further Problem Description:
StatusStatus
Open
Severity Severity
6 - enhancement
Last Modified Last Modified
In Last Year
Product Product
Cisco Unified IP Phones 9900 Series
Technology Technology
1st Found-In 1st Found-in
9.0(0)
CSCsb68946            Bug Details
SIP phone needs to replace digits with "*" in FAC
Symptom:
Currently, TNP phones (tested on 7970) will not block out the digits dialed for a FAC code.
Conditions:
Dialing a translation pattern with "Forced Authorization Code" from the phone will result in code digits being display on the phone while typed.
Workaround:
None.
StatusStatus
Open
Severity Severity
6 - enhancement
In Last Year
Product Product
Cisco Unified IP Phone 7900 Series
8.0(0.8)
Cheers!
Rob
Is there a fix for this bug?
Rob Huffman
Hahahaha Great question!
It looks like this new Firmware may have resolved this issue;
Cisco Unified IP Phone 8961, 9951, and 9971 (SIP) Release Notes for Firmware Release 9.2(1)
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/9971_9951_8961/firmware/9_2_1/release_notes/9900_8900_921.html#wp219168
Forced Authentication Code and Client Matter Code Support
The Forced Authentication Code (FAC) and Client Matter Code (CMC) Support feature extends the FAC and CMC features to more Cisco Unified IP Phones.
FAC controls the types of calls that certain users can place. When placing a call, a user receives a prompt to enter a valid authorization code before the call is made.
CMC enables a user to specify that a call relates to a specific client matter. When placing a call, a user can enter a code to indicate the type of call being placed (for example, to a specific customer).
These enhancements are supported on these Cisco Unified IP Phones (SIP):
Cisco Unified IP Phone 9951
Cisco Unified IP Phone 9971
Cheers!
Rob
