11-20-2012 05:39 AM - edited 03-16-2019 02:17 PM
I'm trying to locate a configuration guide for how to configure VPN on a 9971 phone when using a CUCME system.
This is for my home-lab so can play with this any which way. I have Anyconnect on a ISR.
I assumed, there would be VPN options under the phones menu, however there is nothing that relates to VPN. So, do I need to enable this from CUCME or do I need to configure it fully under CUCME?
Thanks in advance!
11-21-2012 07:55 AM
Has anyone any ideas how to enable the VPN client application on this device? I cannot see any documentation as to this.
11-21-2012 09:25 AM
You need to create a common phone profile that points to a VPN profile and group. Also need to configure a VPN gateway. This is what I have done on 8.5.1
11-23-2012 06:38 AM
Hi thanks for the reply. Is this documented anywhere i.e. any guides I can follow to complete this?
Any configuration you could share would be helpful but no worries if not. I know where the common phone profile is so will us the context help to see if that sheds any light..
11-25-2012 01:20 PM
As far as I can see the vpn profile and group are for SCCP Skinny phones and not the 9971 SIP phone...
I also had to enable the security license on my router to activate the VPN config, but I cannot apply this to the "voice register pool" ephone equivalent config...
Any other suggestions anyone?
