Cisco 9971 SIP - Cisco CME - No DTMF to PSTN
Hi everyone,
We are running CME 8.6 and we are using Cisco 9971 phones and 6921 phones.
The 6921 phones DTMF works fine internally (CUE)/externally (Calling TAC and pressing numbers)
The 9971 phones DTMF works fine intetrnally when calling CUE, but when I make a PSTN calls the 9971's DTFM is not heard by the called party.
Our PSTN provider is configured via a SIP trunk.
Here is the configuration - the phone is set to RTP-NTE and so is the Dial-Peer for the SIP trunk.
voice register pool  1
id mac 5897.1ECC.B19D
type 9971
number 1 dn 1
dtmf-relay rtp-nte
username TEST password 12345
description TEST
codec g711ulaw
no vad
camera
video
dial-peer voice 4 voip
corlist outgoing call-domestic
description ** Long Distance Dial **
translation-profile incoming DID
destination-pattern 1[2-9]..[2-9]......
session protocol sipv2
session target ipv4:172.16.20.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 6000 voip
description Cisco Unity Express Voice Pilot Number
translation-profile incoming MWI_Call
translation-profile outgoing MWI_Call
destination-pattern 6000
session target ipv4:192.168.20.3
dtmf-relay rtp-nte
codec g711ulaw
no vad
Any ideas what could prevent DTMF from making it across?
Manish Prasad
Level 5
Level 5
Can you please share "debug ccsip message" when you call from 9971 to outside PSTN.
Manish
Here you go, I called TAC and was pressing 1, 2 and 7
Log Buffer (10000 bytes):
0 IN IP4 192.168.20.22
s=SIP Call
t=0 0
m=audio 22292 RTP/AVP 0 8 18 102 9 116 124 101
c=IN IP4 192.168.20.22
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:102 L16/16000
a=rtpmap:9 G722/8000
a=rtpmap:116 iLBC/8000
a=fmtp:116 mode=20
a=rtpmap:124 ISAC/16000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
m=video 27888 RTP/AVP 97
b=TIAS:1000000
a=rtpmap:97 H264/90000
a=fmtp:97 profile-level-id=42801E;packetization-mode=0;level-asymmetry-allowed=1
a=imageattr:* recv [x=640,y=480,q=0.50]
a=recvonly
001747: Feb  4 09:52:11.233: //51761/C2EF739B9C60/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.20.22:5060;branch=z9hG4bK3a1aa567
From: "Test User" <1010>;tag=58971eccacaf04595c79af5c-1e7362fc
To: <18005532447>
Date: Tue, 04 Feb 2014 14:52:11 GMT
Call-ID: 58971ecc-acaf008e-2dce3249-2e541be6@192.168.20.22
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
001748: Feb  4 09:52:11.233: //51763/C2EF739B9C60/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:18005532447@172.16.20.1:5060 SIP/2.0
Via: SIP/2.0/UDP 172.16.20.2:5060;branch=z9hG4bK601E1650
Remote-Party-ID: "Test User" <1010>;party=calling;screen=yes;privacy=off
To: <18005532447>
Call-ID: C2F0ABEB-8CE211E3-9C668A32-FDE97735@172.16.20.2
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 3270472603-2363625955-2623572530-4259936053
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1391525531
Contact: <1010>
Expires: 180
Max-Forwards: 69
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 391
v=0
o=CiscoSystemsSIP-GW-UserAgent 1055 7303 IN IP4 172.16.20.2
s=SIP Call
c=IN IP4 172.16.20.2
t=0 0
m=audio 32446 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:20
m=video 27296 RTP/AVP 119
b=TIAS:1000000
a=rtpmap:119 H264/90000
a=fmtp:119 profile-level-id=42801E;packetization-mode=0
001749: Feb  4 09:52:11.237: //51763/C2EF739B9C60/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <18005532447>
CSeq: 101 INVITE
Content-Length: 0
001750: Feb  4 09:52:14.001: //51763/C2EF739B9C60/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
To: <18005532447>;tag=eEg83Ta2Oc3qZVtXn4B0B3AD022b8a0a
CSeq: 101 INVITE
Contact: <18005532447>
Content-Length:   360
v=0
o=Sonus_UAC 1779261955 1261972604 IN IP4 172.16.20.1
s=SIP Media Capabilities
c=IN IP4 172.16.20.1
t=0 0
m=audio 18632 RTP/AVP 0 101
a=sendrecv
a=maxptime:20
a=fmtp:101 0-15
m=video 0 RTP/AVP 119 101
a=sendrecv
a=fmtp:101 0-15
001751: Feb  4 09:52:14.005: //51761/C2EF739B9C60/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <18005532447>;tag=B7010E80-858
CSeq: 101 INVITE
Remote-Party-ID: <18005532447>;party=called;screen=yes;privacy=off
Content-Length: 292
v=0
o=CiscoSystemsSIP-GW-UserAgent 4127 3335 IN IP4 192.168.20.2
s=SIP Call
t=0 0
m=audio 18118 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:20
m=video 0 RTP/AVP 97
001752: Feb  4 09:52:14.093: //51763/C2EF739B9C60/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Content-Length:   360
v=0
t=0 0
a=sendrecv
a=maxptime:20
a=fmtp:101 0-15
a=sendrecv
a=fmtp:101 0-15
001753: Feb  4 09:52:14.093: //51763/C2EF739B9C60/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:18005532447@172.16.20.1:5060 SIP/2.0
Via: SIP/2.0/UDP 172.16.20.2:5060;branch=z9hG4bK601F2326
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
001754: Feb  4 09:52:14.097: //51761/C2EF739B9C60/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Remote-Party-ID: <18005532447>;party=called;screen=no;privacy=off
Supported: replaces
Supported: timer
Content-Length: 292
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
001755: Feb  4 09:52:14.113: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:18005532447@192.168.20.2:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.22:5060;branch=z9hG4bK10faeae3
Max-Forwards: 70
Date: Tue, 04 Feb 2014 14:52:09 GMT
CSeq: 101 ACK
User-Agent: Cisco-CP9971/9.3.4
Remote-Party-ID: "Test User" <1010>;party=calling;id-type=subscriber;privacy=off;screen=yes
Content-Length: 0
001756: Feb  4 09:52:34.729: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:18005532447@192.168.20.2:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.22:5060;branch=z9hG4bK71454614
Max-Forwards: 70
Date: Tue, 04 Feb 2014 14:52:29 GMT
CSeq: 102 BYE
Content-Length: 0
001757: Feb  4 09:52:34.733: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Tue, 04 Feb 2014 14:52:34 GMT
CSeq: 102 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=1036,OS=165760,PR=1070,OR=165272,PL=0,JI=0,LA=0,DU=20
Content-Length: 0
001758: Feb  4 09:52:34.733: //51763/C2EF739B9C60/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:18005532447@172.16.20.1:5060 SIP/2.0
Via: SIP/2.0/UDP 172.16.20.2:5060;branch=z9hG4bK602010BE
Max-Forwards: 70
Timestamp: 1391525554
CSeq: 102 BYE
P-RTP-Stat: PS=1070,OS=165272,PR=1036,OR=165760,PL=0,JI=0,LA=0,DU=20
Content-Length: 0
001759: Feb  4 09:52:34.749: //51763/C2EF739B9C60/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Content-Length: 0
Your provider is sending correct dtmf and there is no mismatch. Can you test few changes
1. Disable video mode from phone then test a call and check dtmf status.
2.check by applying other dtmf method like sip notify.
3.if that does not work then it most look like issue with the phone firmware. Which sip firmware are you using?
