Cisco As 5300 router
fahadqureshi
Dear all,
Can we use Cisco AS 5300 router as a MGCP if yes i i will add this router in Cisco CCM as a gateway, because is the add gateway drop down As 5300 not mentioned there.
really appricaite quick reply
regards,
Fahad
paolo bevilacqua
Do not use MGCP.
Use H.323 or SIP for much better results and stability.
Hmmm thanks
if possible can you please help me out in SIP config
Have you considered reading the product documentaion, srnd, or just searching the forum ?
