Cisco ATA 186 SCCP
rusfatman
Hello.
After the reset of Cisco ATA 186 the first line doesn't register in auto mode. in the same time the second line is working correctly and it's register in auto mode and get a autonumber.
I don't know why it's so.
Can anybody help?
Manish Gogna
Can you check the following setting on ATA page
EPID0orSID0 and EPID1orSID1
SIDx specifies whether to enable the Phone 1 and/or Phone 2 ports on the Cisco ATA to register with Cisco Call Manager. (EPIDx is not for SCCP.) SIDx can be one of the following values:
0—Disables port; port does not attempt to register with Cisco CallManager
. or <mac_address>—Uses the default Skinny ID, which is the Cisco ATA MAC address (MAC) for the Phone 1 port and MAC[1-5]+01 for the Phone 2 port. The port attempts to register with Cisco CallManager.
Manish
- Do rate helpful posts -
No, it's OK.
Screenshot was attached.
