IP Telephony and Phones
Labels
Is there a way to export only one gateway or certain number of phones via BAT? If I use BAT (export/import > export) and select for example gateway, it will export more that 1000 gateways (same with the phone) with FXS/FXO and T1. I just need one so ...
nitesz010 by Level 1
  • 310 Views
  • 1 replies
Just curious if anybody has an idea what course of action I have in regards to the 7965 phones which have component issues which cause them to fail after a power cycle.  I have reached out to our local Cisco rep with no luck.  Also the phones are not...
Hello, I have one issue about one implementation I have CUCM integrated with one PBX. When i receive the call from PSTN the gateway i receive three digitsExample: 403 is send to gateway and the CUCM prefix 0 inside the H323 Gateway, 0403 because the ...
