Cisco ATA190
chrisbell1
Hi there,
Is it possible to manage ATA190 units without CUCM?
I'm wanting to use one as a SIP endpoint for Microsoft Skype for Business.
Cheers!
Since they are SIP endpoints, you can register them with any SIP server such as S4B. The only thing that you need to set the right attributes in the config file. ATAs won't work independently they need to register with SIP server.
Hi Mohammed,
Thanks for the response - I'm searching for a configuration guide online but everything points to using the CUCM.
Do you have or can point me to any documentation on the provisioning process without CUCM?
Cheers,
Since its Cisco product, you will get cisco docs only pointing to cucm. You need to be able to manipulate that to connect to S4B but I doubt there is a doc for this.
