Cisco Attendant Console Standard
Hi everyone,
I Have a customer that has two attendant console standard version 11 installed in your environment, it's working fine, but they want to use the USB Headset connected on PC to answer the calls, is it possible?
Tks
Chris Deren
AC is not a soft phone it's a client only that control a phone. If you want to use AC with soft phone then they will either need to log onto IP Communicator or Jabber client with the AC instead of physical phone.
Chris Deren
Chris Deren
Thanks for your answer,
Ok, So, I'll install the jabber to permit that they use the headset on their PC and will stay all ok.
Thanks a lot
