Cisco Call Manager 8.6.20000-2 After publisher restart all services down
rsanchezuw
Hi all,
after restart the publisher all services are down.
admin:show version active
Active Master Version: 8.6.2.20000-2
Active Version Installed Software Options:
cm-locale-es_ES-8.6.2.1000-1.cop
admin:utils service list
Requesting service status, please wait...
System SSH [STARTED]
Cluster Manager [STOPPED] Service Not Started
Service Manager [Not Running]
Warning: Service Manager need to be running for all Call Processing Applications
admin:utils service start Service Manager
Starting Service Manager...
admin:utils service start Cluster Manager
Service Stopped
admin:
Please, I need your help!!
Roberto.
6 Replies 6
Manish Gogna
Most likely the file system is corrupted, you can download the recovery iso from cisco.com for version 8.6.2 and correct the file system errors using the same.
Manish
- Do rate helpful posts -
Hi Manish and thank for your fast reply.
Could you say me how can i do that? Do you know a how-to?
Plz check this
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/118948-technote-cucm-00.html
Manish
The process remains same for MCS servers, you just need to download the recovery iso, burn it on a dvd and boot the server using that dvd and follow instructions as per above doc.
Manish
I will  try. I'll send you the results.
Thanks a lot.
Roberto
Hi Manish,
i apologize for the delay.
After opening a TAC to cisco a problem was located in slot of the server where it was connected one of the memory modules.
After changing the server card problem was solved.
Roberto S.
