05-04-2017 12:50 AM - edited 03-17-2019 10:14 AM
Hello there! I have one question gyus. Its about CUCM.
How can i get info about phones and numbers that are not using at this moment ( + log of date when it was stop using)
Now i have 4000 + and i have to find numbers that are not using.
Route plan report -- Unassigned DN method is not working, some of DN are in use.
Thanks.
05-04-2017 01:10 AM
Assume Not Using You mean to say Phone/DN is registered but no call are made/received on particular Extension.
Assuming you have the CDR enabled
You might Need to extract the CDR Logs for duration ( Note CUCM CDR Available for last 60 or 90 days by default ). CDR will be in raw format.
And Analyze the CDR to find our extension in Use. Rest you can assume are not in use for the duration of CDR being available.
05-04-2017 01:25 AM
Thanks for your answer.
How can i get CDR enable please ?
05-04-2017 01:31 AM
Enabling CDR Now won't Help.
Just check Two Parameter in CUCM Enterprise/Service Parameter
Call Detailed Records Enabled
Log CDR with Zero Flag
05-04-2017 01:36 AM
Again thanks for answering.
But i cant get it. Where i can see/enable these functions ?
Sorry if im borring you
05-04-2017 01:39 AM
Just go to CUCM>System>Service Parameter
Choose the CUCM Node . ( You have to enable it on all the nodes)
and Service Call Manager
and search for below
False |
05-04-2017 01:45 AM
05-04-2017 01:51 AM
The Point is CUCM will start collecting CDR from the point when this Parameter was enabled, So enabling it now will allow use to Collect CDRs in Future.
If CDR Enabled Flag was set to true on all the Nodes the you are good to go.
With CDR Log Calls with Zero duration refer below details.
05-04-2017 01:55 AM
Got it. But please tell me how can i get now an log information from CUCM GUI ?
Some additional options should be enable now ?
Thank you.
05-04-2017 02:03 AM
Did you refer the link below.
https://supportforums.cisco.com/document/53056/understanding-cdr-call-detail-records
JB
05-04-2017 02:32 AM
Browse to https://cucm_ip/car/.
05-04-2017 03:54 AM
Thanks that is really helpfull. But im inside and i have ine more question:
how can i get table/info about not using phone numbers ? i can not find it
05-04-2017 04:04 AM
You will get the list of Number which are In Use.
There is not table which says Numbers are Not In Use. You have to just exclude the "Numbers In Use" form the Complete list to get the same.
Just go to CDR> Export CDR CMR
Select the date range, Click on Export to file, wait for process to comelete.
Make sure you don't delete the files form system after export , Uncheck the box Delete file
Righe Click and save file.
This is raw CDR Formate, Open it in Excel and you can find the list of extension.
05-04-2017 01:52 AM
"CDR Log Calls with Zero Duration Flag" is not mandatory it only need to be turned on if you want calls with Zero duration to be logged in CDR.
JB
05-04-2017 01:47 AM
You can follow the below link for better understanding.
(Rate if it helps)
JB
