01-19-2016 07:42 PM - edited 03-17-2019 05:34 AM
I have an issue that's strange and puzzling to me. I have a Call Manager Express 10.5 with a connection to a SIP proxy provider for service, I have one DID. The outbound calls work with no problem, but the inbound calls fail. Even stranger is if I simply remove the user credentials from the SIP-UA config and put them back I can make inbound calls for a short time then back to no inbound calls working, I can recreate this fairly consistently. If I do a "debug voice ccapi all" on my CME and place an inbound call I get nothing in the debug logs. I am attaching the configuration. Any help is greatly appreciated.
Solved! Go to Solution.
01-21-2016 10:35 PM
as Vivek correctly stated (+5 V.), the problem is with registration timeout on provider side.
to solve that issue add what follows under sip-ua configuration section
registrar dns:did.voip.les.net expires 3600 refresh-ratio 50
hth
Carlo
01-22-2016 08:40 PM
Seems fine. You can also set 'refresh-ratio 50' as suggested by Carlo which will ensure that gateway will try to re-register at half of the registration time.
- Vivek
01-19-2016 10:34 PM
Can you please do the following:
1. Under SIP-UA configure the command authentication username xxx password xxx realm did.voip.les.net
2. While incoming calls aren't working, try to ping did.voip.les.net and share the IP address
3. While incoming calls aren't working, share the output of debug voice dialpeer and debug ccsip messages
01-21-2016 03:24 PM
Hi Mohammed,
I got the authentication under the SUP-UA.
While incoming calls aren't working I can ping did.voip.les.net as shown below. For the debugs I get literally no output... zero console messages, and yes term monitor and logging console are both enabled. When I test a call from outside it just rings 3 or 4 times then a busy signal. After the missed call I get the following email from my peer. However outbound calls are no issues at all.
You missed a call from 1706XXXXXXX to your DID 1706528XXXX because your peer was offline
Further in my management portal for the CDR it says "busy" for the call disposition.
CME#
Jan 21 18:16:11: %SYS-5-CONFIG_I: Configured from console by console
CME#ping did.voip.les.net
Translating "did.voip.les.net"...domain server (8.8.8.8) [OK]
Sending 5, 100-byte ICMP Echos to 64.34.181.47, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/29/44 ms
CME#
01-21-2016 09:18 PM
Is it peer to peer trunk or getting registered with service provider?
If it is peer to peer trunk and you are not getting any logs during incoming call, all you need to check with your provider only.
If SIP trunk uses SIP registration, I suggest to check the SIP registration status when incoming calls are being failed. Try to shorten the SIP registration timer (150 to 200 sec) and see how it goes.
- Vivek
01-21-2016 10:35 PM
hth
Carlo
01-22-2016 05:54 PM
Hi Vivek,
Could you please give the sytax for this command?
Would this be it?
sip-ua
registrar dns:did.voip.les.net expires 120
01-22-2016 08:40 PM
- Vivek
