Cisco Callmanager 6.1 Issue
INFOTEP_OFN
hello
I have CCM 6.1, I'm trying to change the configuration of the route patterns, but when I made the changes, and go back to the list, the server is not saving the changes. Any help please
5 Replies 5
acampbell
What are you trying to change in the route pattern.
I can try the same on my 6.1 lab
Alex
Regards, Alex. Please rate useful posts.
Hello
I'm tryint to change the gateway in one pattern, also when I create a new dosen't show up.
I am runninig 6.1.4
I can change the getway on the route patterns
I can also add new patterns.
Could this be the account you are using.
I am a full CUCM Admin user.
Perhaps you need a TAC case.
Alex
Joseph Martini
Can you update and save other items such as settings on a phone properly?
Rob Huffman
Hi Yancy,
Just to add a note to the good tips from Alex and Joe (+5 each )
I would open a TAC case here as I see a number of related bugs on
CUCM 6.1(3) but fixed in 6.1(4). here is one example, it's not exact
but i think we may see a pattern here.
CSCta15734
Changes in RL not taking effect.
Symptom:
Whenever you remove and add back in a RG, after that change its priority in the list the replication specifically for the RL table breaks, and NOT the whole DB Replication.
Conditions:
Replication for specific table is seen to be corrupted.
Workaround:
Following steps can be done to workaround the problem;
- Do a 'utils dbreplication repair' from the publisher.
- Reset the RouteList.
Your issue will be fixed after that unless until you decide to make changes in the RL again.
Also this issue might not be limited to routelist table alone, Issuing utils dbreplication reset all will ensure that any other tables which have a problem with the indexes on the subscriber are also recreated.
Related Bug
Status
Fixed
Severity
3 - moderate
Last Modified
May 06,2010
Product
Cisco Unified Communications Manager (CallManager)
Platform
Dependent
Technology
nav
1st Found-in
6.1(3)
Fixed-in
7.1(3), 7.1(3.10), 7.1(4.1), 7.1(3.6), 7.1(3.7), 7.1(3.9), 7.1(3.11), 7.1(4.4), 7.1(4.6), 7.1(3.10000.5), 7.1(4.5), 7.1(3.38000.48), 6.1(4.1110.1), 8.0(0.98000.17), 6.1(4.39000.111), 7.1(2.32014.1), 6.1(4.17), 7.0(2.22030.1), 7.1(3.10000.11), 6.1(4.18), 7.1(3.8), 6.1(4.19), 6.1(4.20), 7.1(3.99999.6), 6.1(4.21), 6.1(4.22), 7.1(4.2), 6.1(4.23), 7.1(4.3), 6.1(4.24), 6.1(4.25), 6.1(4.26), 6.1(4.27), 7.1(4.7), 6.1(4.28), 7.1(4.8), 6.1(4.29), 7.1(4.9), 6.1(4.30), 7.1(4.10), 6.1(4.31), 7.1(4.11), 6.1(4.32), 7.1(4.12), 6.1(4.33), 7.1(4.13), 6.1(4.34), 7.1(4.14), 7.1(4.15), 6.1(5.10000.10), 7.1(4.16), 7.1(4.18), 8.0(1.10000.40), 7.1(4.19), 7.1(4.21), 7.1(4.22), 7.1(4.23), 7.1(4.24), 7.1(5.10000.12)
Cheers!
Rob
