CISCO CDR ERROR 10021
mandarpai2
The CDR Load is in Disable Loading. I am not able to change it into default settings or to Loading 24*7.
It will show like your request is processing then the server is not responding.
The callmanager version is 6.1
All the 4 values of MIN_DATE.CDR_MIN_DATE and rest 2 are matching and is avaliable in CLI mode.
Dont know how to proceed.
Please someone help me.
Aman Soi
Hi Pai,
Di d u try restarting CAR scheduler service.
Please do the following procedure for error u are getting;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080933fcf.shtml#Problem2
Error Code 10021
When an attempt is made to access CDR Search and CDR report from CDR Analysis and Reporting (CAR) on Cisco Unified Communications Manager (CallManager) 5.X, this error message appears: Error Code 10021 There is no matching records.
Similarly, when an attempt is made to collect data, CAR is not able to collect data and this error message appears: 30023: Data is not available for the date range selected.
Solution 1
  1. This error can occur when the Disable CDR loader check box is checked in CAR. Choose System > Scheduler > CDR Load, and uncheck the Disable Loader check box in order to resolve the issue.
  2. Choose System > Service Parameters, and click the Advanced button in order to display the list of Service Parameters. Make sure that the CDR EnabledFlag is set to True.
Solution 2
Complete the steps mentioned in the Solution for the Error Code 10012.
If these solutions do not solve the issue, contact the Cisco Technical Assistance Center (TAC).
Complete these steps:
  1. Reset the MAX_CDR_NUMBER to a default of two million. Run this query from CLI:
    admin: run sql update car:tbl_system_preferences set
              param_value='2000000' where param_name='MAX_CDR_NUMBER'.
  2. Choose System > Scheduler > CDR Load. Select Disable Loader, and click the Update button in order to disable the CAR loader.Note: CDR data does not load into CAR until you enable CDR loading. Changes take effect at midnight. In order to force the change to take effect immediately, stop and restart the CAR Scheduler service.
  3. Re-enable it, uncheck the Disable Loader check box. Check the Continuous Loading 24/7 check box, and click the Update button.
  4. In order for the changes to take effect immediately, stop and restart the CAR Scheduler service.
regds,
aman
7 Replies 7
Aman Soi
Hi Pai,
Error Code 10021
Solution 1
Solution 2
regds,
aman
Thank you fro your quick reply.
Only one one callmanager server is there.
We have tried it i have attached the screenshot , when i made the Continuous Loading 27/7 and click update then the server is not responding.
i have made it to that and updated it. surprising now the Disable Loader is checkmark automatically, we are not able to change it and update.
Kindly let me know the next action plan.
Hello anybody can help me. One month CDR is missing can anyone help me
Hi Pai,
Is your first problem resolved?
Secondly, do u get any error message/warning while taking CDRs?
regds,
aman
no both are not resolved Aman.
Now i cannot change CDR load settings as well as 10021 error.
Event LLogs i can unscusseful tasks from march 16th onwards.
Hi Pai,
What I suggest u Open the TAC case with cisco  to resolve both the issues since main problem of DISABLE CDR LOADER/Loading 24/7 needs to be resolved first  because it almost hangs.
regds,
aman
ok i will do it
