Cisco CME Adding Didgits to the end of dialed numbers
exonetinf1nity
Greetings, i have a CCME setup running version 7.0, inbound and outbound calls are working as expected except that call setup for outbound calls can take anywhere from 5 - 15 seconds, ive spoken with a couple of people in regards to this issue as such one person mentioned adding "#" at the end of the number which set's up the call immediately.
Is there a way i can re-configure the existing outbound translation profile to add "#" at the end of every number sent to the SIP provider.
I do realise that the Interdigit timeout value can be decreased which is currently set for 6 seconds but the telephony users report that when the timeout is set for 2 - 3 seconds it is not enough time to dial a number...oh i despair!
Current config.
voice translation-rule 2
rule 1 /^999$/ /999/
rule 2 /^9\(.*\)$/ /\1/
voice translation-profile SIPOutbound
translate called 2
dial-peer voice 2 voip
description **Outbound call to SIP**
translation-profile outgoing SIPOutbound
preference 1
destination-pattern 9T
voice-class sip dtmf-relay force rtp-nte
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
no vad
Maybe you should be more specific with your dial peers. Create some for the 7-digit dialing (destination-pattern 9[2-9]......) one for long distance (destination-pattern 91[2-9]..[2-9]......
prefix 1)
and so on.
Your 9T pattern matches everything and relies on the interdigit timeout to call out.
Dragi
Cheers for that ill adjust accordingly.
Yep thats done the trick, thank you for your time.
