Cisco Conferance phone 8831 compatability
adnanhassan1
Hi Guys,
Just wondering if someone know Cisco 8831 is compatible with CME version 7.0(1)?
If so, what should be the correct type under 'voice register pool xx'?
Adnan
Jitender Bhandari
it is not supported
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme71spc.html
for all CME compatibility see below
http://www.cisco.com/c/en/us/support/unified-communications/unified-communications-manager-express/products-device-support-tables-list.html
As i see it is supported with latest.
JB
Chris Deren
No it is not, see:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmeroad.html
also, look into CME fast track feature, which I believe was introduced in CME 10.5:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/feature/phone_feature/phone_feature_support_guide.html#_Toc436645184
+5 Chris. This is supported only starting from 10.5 using fast track feature.
